Yet another VTC question, a little different this time...
Old May 4, 2003 | 12:27 PM
dmontzsta
I was curious, if you advance your timing...drive for a few days, then ground your VTC's, would it mess with the timing? ie: when you go to unground them again, would the timing be the same?
Old May 4, 2003 | 02:15 PM
Maximajism94se's Avatar
i imagine if u hooked up a timing light 2 the car b/f and after thatd tell u...vtcs only affect top end timing so i wouldnt think it makes a difference, but this damm car is so complicated who knows...
Old May 4, 2003 | 04:08 PM
m_maxxy's Avatar
Re: Yet another VTC question, a little different this time...
I thought VE engines don't need timing adjustment... At least this is what said about them in Haynes.
Old May 4, 2003 | 08:11 PM
todamax's Avatar
If VTC's only affect top end, why did my cold idle go to hell after I grounded them things?
Old May 4, 2003 | 08:19 PM
gdmaxse's Avatar
the vtc are cam timing, the "timing advance" thru the cam angle sensor is ignition timing (when the spark fires) so i dont think they affect each other
Old May 4, 2003 | 10:16 PM
well darn...i dunno exactly, see i knew i prolly wasnt sayin it right, but i didnt feel like using the brain power, but u get the point...only affects timing at certain times u would think, not thruout the powerband...besides, i wouldnt know cause mine work
ps, when i ground mine when i change my oil my idle changes, but is not crappy...
Old May 4, 2003 | 11:29 PM
shoult's Avatar
Why would you ground them when you change your oil?
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
