Switch question / AT
I'm not sure to be honest, but if it works anything like the Vb mod (which gives you quicker shifts) it would prolong the life of your tranny. But now that I think about it, it probably won't, because if it did everyone would drive around with the switch on power, trying to get 200,000 + miles our of their tranny.
If you just leave it in the middle, you will get better gas mileage. The car has a brain that tells it when to shift secondary to throttle control. If the vehicle accelerator is pushed to the floor, the car knows to use the Power mode and will turn off your A/C if using. If you want comlete power all the time, then switch it. On trips, use the comfort, you will notice a diffence...
Reese
Reese
James92SE
Oct 8, 2015 04:57 PM
Jeff92se edit: Don't post like that. Thanks.
