Window Problem
Old May 6, 2003 | 05:35 PM
MaximaGuy719's Avatar
Window Problem
My front windows go up normal until almost the end and then the glass gets out of position and leans to the right(away from the rear), leaving me to have to push them back to get them up.
Should I take the door apart and see if I could straighten it out? Has anyone ever had this problem?
Could it be the window regulator? I don't think so, but who knows?
Old May 6, 2003 | 05:44 PM
Gjohnson's Avatar
Yea, definitely take the door off and see what the problem is, I wouldn't pay someone all that labor when you might be able to fix it.
Old May 6, 2003 | 08:35 PM
rbloedow's Avatar
Have you changed your regulator in that window recently? When I did mine, I didn't line the window up perfectly in the track, so I had the same problem. Open it up and chekc it out
Old May 6, 2003 | 08:43 PM
GReDdyXMaXiMa
I m having some problem with driver window , Every time I put the window down and then it wont go up unless if i press n hold it for 5 minutes then it ll go up . What the hell is that ? Could it be switch ? any ideas?
Old May 6, 2003 | 08:57 PM
Nope having changed it
Old May 6, 2003 | 10:11 PM
Lazie~krone's Avatar
I know its kinda diff. problem but still a window prob. my window if its like rolled up half way its really loose and if i closed the door i hear it hit the sides or it bounces around in there.
pears
Sep 18, 2015 05:25 AM
thenewguyy
Sep 12, 2015 11:12 AM
markevans999
Sep 10, 2015 04:29 PM
ef9
Sep 5, 2015 11:18 PM
