Plenum question (Replacing Fuel Injectors)
Old May 10, 2003 | 02:26 PM
todamax's Avatar
I'm taking apart my '89 GXE to replace a couple of fuel injectors. I got the plenum off, and found that it looks a little strange. Now, I'm a novice, and I don't "know" what this is supposed to look like, but I'm thinking that someone here can tell me if there is a problem or not.
I lot of cruddy hard little pieces of crap around the right edge.
Anybody wanna trade 4 good yellow dot '93 injectors for 4 good '89 blue dots?
Old May 10, 2003 | 03:02 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
I'm no expert but that looks like some serious carbon buildup...mine wasn't half that dirty, WOW!
Old May 10, 2003 | 03:18 PM
crazy4maxima's Avatar
that is some sick pic.. is it rusting too?? get some throttle cleanre and clean that bish up.. btw how much for the gasget.. i want to take off mines and clean it up in there.. btw those hex bolts are a pain in the as$.
Old May 10, 2003 | 09:51 PM
todamax's Avatar
No its not rusting, its just oil sludge buildup...
Old May 11, 2003 | 09:39 AM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
get some wire brushes and some carb cleaner and get to work
Old May 11, 2003 | 09:50 AM
D-sta's Avatar
Yikes.....yes please get that cleaned A.S.A.P.
Old May 11, 2003 | 10:33 AM
todamax's Avatar
Yeah, it will be cleaned, but is it a problem of some sort?
Old May 11, 2003 | 10:38 AM
D-sta's Avatar
It's just not good, the cleaner the better combustion.
Old May 13, 2003 | 07:15 PM
jkmay01's Avatar
Lil 8
the plenum gasket is like 34 or so at the dealership, yea get a brush and carb cleaner and get busy with the carbon removal. What grade of gas are you using?
Old May 16, 2003 | 12:52 PM
keener's Avatar
Upper and lower plenum gaskets are $21 at the dealer.
Old May 17, 2003 | 08:00 AM
CandiMan's Avatar
Say Candyman 5 times
Originally posted by todamax Yeah, it will be cleaned, but is it a problem of some sort?
I think it could be caused by various things like, not changing the oil at proper intervals, driving the car at low oil temps for short intervals, using cheaper quality engine oil (ones with no detergent properties), a high mileage engine, etc. Does it appear to be a problem of some sort, I don't think so. It does appears to be maintenance related. Try using a motor flush once the engine is back together and avoid the things I listed earlier, except the high mileage part.
Old May 17, 2003 | 08:15 AM
nubiannupe's Avatar
OG Maxima.org Member
I wonder if he drove backwards, could he avoid the high mileage part?
Old May 17, 2003 | 09:21 AM
D-sta's Avatar
Old May 17, 2003 | 09:53 AM
todamax's Avatar
The fun continues today. Waiting on the injectors, so I'm attacking the leaking possibly broken exhaust studs.
Old May 17, 2003 | 02:46 PM
1337haxor's Avatar
I can't believe you are such a tard!! You should have cleaned that like 5 years ago you fu(k1ng 14m3r. Jeez. What the hell is wrong with you.
Old May 17, 2003 | 02:47 PM
1337haxor's Avatar
BTW, Did I mention that both of your cars are lame?!!?!
Old May 17, 2003 | 03:34 PM
todamax's Avatar
Why don't you p0st something c0nstructive?
At least my cars have a suspension that works...
Old May 17, 2003 | 06:53 PM
1337haxor's Avatar
I like my lame cadillac feel so shut up (voice cracking)
Old May 17, 2003 | 07:51 PM
todamax's Avatar
at least the exhaust studs are intact on your car...
Old May 17, 2003 | 07:57 PM
1337haxor's Avatar
It has everything to do with the rigorous preventive maintenence that I perform on them every 1500 miles.
kjlouis
Nov 24, 2018 06:09 AM
Finkle
Sep 27, 2015 09:53 PM
lux97Max
19
Aug 27, 2015 07:48 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Balkins
Aug 12, 2015 06:39 AM
