warm negtive battery terminal
problem: the negative terminal on my max's battery is pretty warm to the touch. the engine was still cold.
i notice it yesterday when changing the fuse on my amp's fuse holder thing. my forarm touched it and i though wow that's warm.
what can cause this? i checked the wires to see if any are damaged but they seem ok. any ideas/help would appreciated. thanks a lot.
A warm terminal means there is a voltage drop accross the terminal (meaning there is resistance caused by corrosion). If you have stock terminals then I dont find this surprising. What I suggest is that you clean the terminals. You can remove the terminal, and use warm water mixed with some baking soda. Then insert the terminal in the solution and you'll see it fizzle (the corrsion will dissolve away). Then thuroughly(sp?) dry the terminal. I'd suggest also using a 'battery terminal brush' also to clean both the terminal and the post. After reassembling then use a small amount of bearing grease or dielectric grease and apply a thin coating on all exposed metal (the terminal and post, exposed wire) to help prevent oxidation from occuring again.
Note: do not get any of the grease on the area that makes electrical contact (meaning the outside of the post that contacts the terminal). So only put on the grease after the terminal is secured back in place.
You should also notice the engine turn over faster!
![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
06-06-2017 02:01 PM
bigfrank
10-01-2015 12:51 PM
