buying a 90SE maxi
buying a 90SE maxi
hey guys, I am an alti onwer (from altimas.net) and my friend is buying a 90 Maxi SE. I tried to inspect the car a little bit, and things looked as following:
The engine bay is dirty, and it definitely needs some TLC. brakes function good, and I have noticed some rust on the door sides, which is normal in Indiana... exhaust manifold (bottom) part is a little rusty due to the snow.... I heard some *squicking* sound from the engine bay, sounds like the belt needs to be replaced...
Is there anything else I need to notice about (tranny, engine wise)? I mean, I tried to apply my alti knowledge into the maxi, but it isn't enough... so any advice will be great!
1990 Maxi SE, Black, 11xxxx miles, automatic...
thanks a lot guys.
thanks a lot guys.
It's a VG, there's really no big issue you should look for. Just your normal wear and tear.
-axles (CV boots and what not)
-steering rack
-any leaks
-belts
-if it hasn't already timing belt changed is a good idea (also gives your friend an excuse to get a UDP)
-suspension
-motor mounts
So on and so forth... the VGs are bulletproof so like I said before, just look for normal wear and tear.
-steering rack
-any leaks
-belts
-suspension
-motor mounts
yeah, that's what I figured... the VG is nice... but the car does need some TLC, and my friend and I gonna work on that to make it at least nice and shinny, clean engine bay. and we will start from there...
Thanks for the advice Dark Lord Bunny
Apr 16, 2020 05:15 AM
magiconthetire
Oct 26, 2015 09:03 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
