Adjusting Idle
Old May 31, 2003 | 04:20 PM
90inthemaking's Avatar
Adjusting Idle
I've seen responses in other thread's that you can adjust the idle yourself, I think that my idle is too low and I was wondering can anybody tell me how to do this. Any response would be helpful
Old Jun 1, 2003 | 09:00 AM
mtcookson's Avatar
the ecu has the idle adjustment screw. if lay down on the passenger floor and look behind the radio area you'll see your ecu back there. there is a screw on it and it says idle adjustment. that screw is also how you check the diagnostics.
Old Jun 1, 2003 | 10:38 AM
eric93SE's Avatar
Are you smoking CRACK
That screw is only to run engine diagnosis (I've never heard differently).
90inthemaking: Yes you can ajust the idle, its very simple. All you need is a long screw driver (either philips or flat head will work). The screw is located under the throttle body, maybe 5 or 6 inches down, its actually on the IACV (idle air control valve). I've found that one full c.c.wise turn will raise the idle in 100rpm increments.
I dont think the search is working, but if it were you could find an old thread on how to clean the IACV (by me), b/c thats whats really causing your poor idle. But its perfectly okay to raise the idle with the screw to compensate for the IACV. Raise the idle to at least 800rpm (not too much higher).
I forgot to mention the idle screw points forward (towards the radiator) and its a bit recessed (flush with the IACV).
Old Jun 1, 2003 | 11:23 AM
I don't mean to sound ignorant but what is the throttle body?
Old Jun 1, 2003 | 11:31 AM
eric93SE's Avatar
Actually we have different engines, wait for someone with the vg engine to reply.
Old Jun 1, 2003 | 01:49 PM
TLM's Avatar
TLM
what is the "ideal" level for an idle?
Old Jun 1, 2003 | 04:15 PM
mtcookson's Avatar
i'm sorry but the little sticker right on the ecu says idle adjustment. i have two ecu's sitting on my table and they both say the same thing. check it out sometime (this goes for the vg engine)
i think about 700-800 rpm is good idle.
Old Feb 5, 2014 | 06:55 PM
jessi89max's Avatar
Jus messed up my idle air control valve by putting throttle body cleaner in it snd putting it back any one no hoe to save the iacv
Old Feb 5, 2014 | 06:57 PM
jessi89max's Avatar
Cant believe i messed it up
Old Feb 5, 2014 | 07:25 PM
ac max 92's Avatar
That sounds a little harsh considering there is an idle adjustment on the ecu. Atleast on the vg anyway. I can find out if you can adjust it on the ecu on the ve aswell.
Old Feb 6, 2014 | 10:03 AM
DanNY's Avatar
Ad·min·is·tra·tor
post date 06-01-2003
you're referring to a post 11 years ago.
Old Feb 6, 2014 | 10:49 AM
ac max 92's Avatar
LOL thanks danNY i just noticed it was on yesterdays posts by jessi89max but didn't look at the date of the previous posts.
Old Feb 15, 2014 | 11:15 PM
jessi89max's Avatar
Got a iacv on ebay 15 bucks
tarun900
19
Dec 20, 2021 06:57 PM
leatherneck
Sep 30, 2015 09:16 PM
salty318
Sep 29, 2015 01:21 PM
