4x blinker
Old Jan 26, 2001 | 06:40 PM
abdiddy's Avatar
I just recently bought a relay that makes my blinkers blink 4x faster but I can't find where the 4x bliker relay goes to replace my old one. The person on E-bay I bought it from said that it should be next to the fuse panel but I still can't find it. Does any oner have this mod on their car. If so can you tell me where the blinker relay is because all I have to do is remove the stock relay and put in the 4x one. Thanx
Old Jan 26, 2001 | 07:00 PM
HoJo's Avatar
Check under the hood next to the battery.
Old Jan 31, 2001 | 09:58 PM
abdiddy's Avatar
4X blinker
Does anyone know where the relay for a 1990 maxima SE is. I bought 4x blinkers that makes blinkers go 4X faster. It goes where the factory relay is but I can't seem to locate the relay for the turn signals. The person who sold it to me told me to check under the dash by fuse box but I still can't find it. Somebody please help!!!
Old Feb 1, 2001 | 07:03 PM
91MaximaGxR's Avatar
i hope someone knows where it is because i just bought the same relay!
Old Feb 1, 2001 | 07:16 PM
Botnik
I know exactly where the relay is. You need to remove the entire plastic cover under the steering wheel. The relay is underneath the steering wheel to the right. Its inside some casing. You need to use a flathead screwdriver to pry it downward. Your 4x blinker relay will be too big to be pushed back up into the casing but you can just leave it hanging. To make it easier to find, turn on the signals and look for a clicking relay. When you touch the correct relay with the signals on, you can feel it ticking. Hope this helps.
1maxTaDie4
Feb 2, 2001 01:57 PM
1maxTaDie4
Feb 1, 2001 11:38 PM
MacGyver
Dec 30, 2000 10:38 AM
2000MaximaSE
18
Sep 27, 2000 10:42 PM
