Soon to be new Maxima owner here.
Old Jun 12, 2003 | 07:17 PM
mlounsbury's Avatar
Wassup peoples. Just wanted to post and say that I'm going to be aquiring a 89 Maxima in the next week. Has a new transmission in it, and it seems to run well, except needing new lower ball joints and a flex pipe. It has ~190K miles on it.
Just wanted to know what I should be aware of on a Maxima with that many miles, if I might need to replace anything else sometime soon.
At any rate, here is a link to some pics if you want to check it out.
http://mywebpages.comcast.net/malounsbury/maxima/
Thanks in advance!
Matt L.
Old Jun 12, 2003 | 07:29 PM
dsantos's Avatar
Timing belt... Timing belt... Timing belt...
Look like you are buying this from a dealer. You will not know the history. get the timing belt replaced. If this belt breaks you can bend engine valves. Spend another $300 now over $2000 later.
Old Jun 12, 2003 | 07:36 PM
kingcarnage's Avatar
Check all the hoses too, in fact check anything made of rubber.
Also some people have had motor mounts go bad too.
Old Jun 12, 2003 | 08:37 PM
my2ndmax's Avatar
Whats that blue wire coming out of the left side of the steering wheel?
Old Jun 13, 2003 | 05:01 AM
mlounsbury's Avatar
I'm not buying it from a dealer. Buying it from my wife's dad. Someone came in with it and didn't want to pay for the transmission to be replaced, so I'm just paying him like $500 for it and the car is mine.
Blue wire on the turn signal lever is just a leftover scrunchie from the old owner. Car needs a good cleaning badly.
Thanks for the timing belt tip. Bent valves do suck.
Old Jun 13, 2003 | 05:09 AM
Mizeree_X's Avatar
Getting back to his roots
When you replace the flex pipe, go with an aftermarket one such as www.warpspeedperformance.com, www.stillen.com or www.budgetexhaust.com. The aftermarket ones add ~10-15HP and are cheaper than an OEM one.
Old Jun 13, 2003 | 05:38 AM
mlounsbury's Avatar
Yah, I was looking on carparts.com and all I saw was a Pacesh!tter which I know from my previous Neon owning experience that their stuff wasn't worth it. But I will check out the stuff from those places, Mizeree.
halfpol
Oct 17, 2022 12:16 PM
CRizz
41
Jun 7, 2021 05:42 AM
MplsMadMan
Sep 4, 2015 02:23 PM
Hawkeye61
Aug 12, 2015 06:45 PM
halfpol
Aug 5, 2015 08:24 PM
