Nitrous Oxide question, hehe
Old Jun 19, 2003 | 07:19 PM
  #41
bonzelite's Avatar
at this point, as i have only been reading about it, the idea of wet seems more error prone, as fuel will be introduced into a manifold system not ever intended for such use. i know that people have wet systems. and they seem fine with them i suppose. wet seems to have more potential power gains going for it, however.
Old Jun 19, 2003 | 07:41 PM
  #42
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
Originally posted by male
People who need an easy fuel increase like the Saab cold start injectors...They are constant flow rather than pulsing. Easy and cheap as hell to do.
that will be hard to do with out an ECU reprogram, resistor setup or "AFC hack" setup...the injectors will stay wide open and burn out you can't just pop them in and go. you'll need a method to properly control them...what CC are the Sabb injectors anyways, 310??
Old Jun 19, 2003 | 08:44 PM
  #43
bonzelite's Avatar
DA-MAX,
when boosting with N2O, stock injectors are good depending on what system you use and how much boost you introduce. for example the JWT dry system uses the stock setup with an ECU upgrade. when are stockies no longer appropriate? it is to my understanding that stockies will work fine with huge boost if the engine remains N/A. does this N/A state still apply if you start doing things like porting and boring out the heads, for example? additioinally, in that case, could you not just feed in more fuel pressure while using the stock injectors?
Old Jun 19, 2003 | 08:51 PM
  #44
DA-MAX's Avatar
stock injectors are fine for N20. yeah JWT system is especially good since it controls everything for you. you'll have to check with Jon about the little minor extras like an adjustable FPR. I would assume some minor adjustments on the FPR could match the changes made when you do porting and all that, but I'm just guessing.
Old Jun 19, 2003 | 08:53 PM
  #45
tmnismo91's Avatar
Shouldn't this be in the appropriate forum
Old Jun 19, 2003 | 08:55 PM
  #46
DA-MAX's Avatar
just pretend it is and don't click to view this thread
Old Jun 19, 2003 | 09:31 PM
  #47
bonzelite's Avatar
Jon610,
VG stock injectors can handle 500hp? VQ cannot? VG is like 170cc? i need more info, bro. keep a' comin'. keep a' comin'.
Old Jun 19, 2003 | 10:42 PM
  #48
GReDdyXMaXiMa
Hmm , Very interesting. I like Matt's thought about getting a parts at car-parts.com . All I can say is good luck. I ve been experienced with it, no needed to explain . Let's say action will walk the talk.
Old Jun 20, 2003 | 05:14 AM
  #49
tmnismo91's Avatar
sure thing.
Old Jun 20, 2003 | 09:40 AM
  #50
DA-MAX's Avatar
Originally posted by bonzelite
Jon610,
no stock VG injectors WILL NOT make or handle 500hp! they'll probably max out in the mid 200s if that. VQs are 270ccs and are proven into the 300hp range easy.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
