Y-Pipe installation?
Old Jun 17, 2003 | 03:49 PM
pest2001's Avatar
can i get a how-to on the installation of a y-pipe
Old Jun 17, 2003 | 08:01 PM
maxmizd27's Avatar
I think Warpspeed has the whole program on their site.
www.warpspeedperformance.com.
Old Jun 17, 2003 | 08:04 PM
lophix's Avatar
while you are reading this, i'll advice you to go and start spraying wd40 on all the bolts you'll need to take off unless you have air tools.
Old Jun 17, 2003 | 08:42 PM
pest2001's Avatar
yea i was going to do that hopefully the install is not to hard i want to do it 2-morrow morning
Old Jun 17, 2003 | 09:10 PM
pest2001's Avatar
yea i was going to do that hopefully the install is not to hard i want to do it 2-morrow morning also i want to know if the O2 sensor is in/on the y pipe
Old Jun 17, 2003 | 09:40 PM
KLoWnPR109's Avatar
Soak the bolts the night before. The sensor is in the pipe, screws in. Make sure you've got the correct sockets and an extension at the minimum. You might have to use a breaker bar if they are on there good. Did the pipe come with bolts and gaskets?
Old Jun 17, 2003 | 09:43 PM
shoult's Avatar
NO!!!! NOT WD-40! Use a real rust penetrant like PB Blaster or AeroKroil. And do it every night for a few nights before you are planning to do it.
Also, order all new studs and nuts and have a drill, set of left twist bits, easy out and tap and dies set handy.
Old Jun 17, 2003 | 10:52 PM
pest2001's Avatar
i thought this was a direct bolt on
Old Jun 18, 2003 | 01:26 AM
nubiannupe's Avatar
OG Maxima.org Member
That's just in case some of the bolts don't give way and break.
MaxLife17
Jun 27, 2019 01:37 PM
2kmaximel
Sep 16, 2015 03:19 PM
Violator
Sep 9, 2015 10:14 AM
