Auto shifting
Old Jun 19, 2003 | 10:37 AM
bigbadbeck's Avatar
Auto shifting
I searched, but couldnt really come up with anything solid. Anyway, I am having trouble with my shifter. Two things:
1. When I shift into drive, it will engage sometimes, and others not. If it dosent engage, pulling the **** towards the rear will engage it.
2. Sometimes when I put in in park and turn the car off then come back later and try to start it, the car dosent think it is in park. I have to shift into neutral and then back to park.
Not a big deal, but do you think the problem is just something loose under the shift ****, or something else? Any advice on what to look for/ do?
Thanx
Old Jun 19, 2003 | 11:07 AM
tafan321's Avatar
check the fuses , i had something similar to this and it turned out just to be the fuse.
Old Jun 19, 2003 | 11:39 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
sounds like worn shifter bushings to me
Old Jun 19, 2003 | 11:44 AM
bigbadbeck's Avatar
Ok, if it is worn bushings, what can I do about it?
Old Jun 19, 2003 | 11:51 AM
DA-MAX's Avatar
buy new ones(2 of them) for $2-3 at Nissan and replace them
Old Jun 19, 2003 | 11:59 AM
bigbadbeck's Avatar
scuse my idiocy, where are they located? how hard to replace?
thanks
Old Jun 19, 2003 | 02:17 PM
Gjohnson's Avatar
There is a screw in the front of the shifter ( the shaft I believe) you have to remove the screw and then you can pull it a part. I have the same problem but I beleive I will use it as an excuse to buy the Levco shifter from Custommaxima. (in case the wife asks)
*edit* There is a wire running through the shaft also, I beleive it connects to the overdrive on/off button.
Old Jun 19, 2003 | 07:16 PM
rymo926's Avatar
mine does the same. its the bushing. there is a write up some where
Old Jun 19, 2003 | 07:31 PM
DA-MAX's Avatar
here you guys go...
http://forums.maxima.org/showthread....hifter+bushing
Old Jun 20, 2003 | 03:42 AM
Maxima NutBag's Avatar
I had that problem. replaced them.
Unclejunebug
Apr 2, 2016 05:42 AM
BobTX10
Oct 7, 2015 08:43 AM
hayne
Oct 5, 2015 11:53 AM
