When do you replace the timing chain on a VE?
Old Jun 20, 2003 | 07:42 PM
96ItaliaSE's Avatar
il massimi bassi
Now that I have sucessfully used the org. to correct my minor maxima imperfections I am considering having the timing chains and guides replaced. They rattle a few seconds on startup but go away.
Some one said to use thinner oil, i use 5w50 syntec, i dont seee this as a cure all
Nissan says 100k to replace. I have never seen a VE chain snap(knock, knock).
So I guess at 160k am i sitting duck?
what does you guys think about VE timing chain replacement?
Old Jun 20, 2003 | 08:37 PM
CandiMan's Avatar
Say Candyman 5 times
Re: When do you replace the timing chain on a VE?
When I went inside my VE at 113K I was pleasantly happy with the condition on the chains(3) and guides(few) I thouroughly check the chains for wear and tear, all within normal wear. The guides all had plenty of meat left, again just normal wear. Nissan may say change the chains at 100K but they're saying that for liability or to get money. Steel chains have been known to last a very long time, just ask those 60-70's Detroit guys.
Old Jun 21, 2003 | 07:18 PM
gdmaxse's Avatar
Re: Re: When do you replace the timing chain on a VE?
can you replace the chain tensioner without taking the heads apart, i know theres a panel that allows access on 4th gens but i couldnt find anything about it in my chiltons manual
Old Jun 21, 2003 | 07:23 PM
crazy4maxima's Avatar
call me stupid but doesnt the chain never have to be replaced. arent they gaureented for the life of the max...??
Old Jun 21, 2003 | 07:32 PM
pjalst
That's what I thought
Old Jun 21, 2003 | 07:37 PM
I don't drink, gamble, or do drugs......I JUST DO MODS
Old Jun 21, 2003 | 07:56 PM
Michael's Avatar
Back in a 3rd Gen.
no its not guaranteed for the life of the car.
chains are like everything else they will eventually wear out and they also stretch over time...hence the reasons for tensioners.
Old Jun 21, 2003 | 07:59 PM
well i meant they arent a problem like timing belts.
Old Jun 22, 2003 | 01:54 AM
MrGone's Avatar
hopefully never.
If you do, its because its broken or because its noisy from being to loose, but thats not likely to happen.
MrGone
Old Jun 22, 2003 | 04:27 AM
pjalst
I've been know to have a brew now and then. I also chase wild women.
Old Jun 22, 2003 | 09:50 AM
CandiMan's Avatar
Re: Re: Re: When do you replace the timing chain on a VE?
Originally posted by gdmaxse can you replace the chain tensioner without taking the heads apart, i know theres a panel that allows access on 4th gens but i couldnt find anything about it in my chiltons manual
Yes, all the chains and guides can be removed/replaced without pulling the heads.
Timing chains will last a long time, but ANYTHING that MOVES will wear, anything. (machines, human body, etc)
vingodine
45
May 21, 2016 12:46 PM
maxinout93
Oct 27, 2015 01:29 PM
Balkins
Aug 12, 2015 06:39 AM
laparka66
Aug 6, 2015 09:36 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
