any help appreciated
Old Jun 23, 2003 | 10:40 AM
J93MaximSE's Avatar
OK. A couple weeks ago I thought I had a bad knock sensor. The motor would hesitate until over 3k and then it would haul ***. So I did the knock sensor bypass with the resistor. It really did work. For one day it worked. The power would kick in so much sooner and my low end was way better. Next day I wake up all happy to find that it hesitates again. OK, so i bought and replaced the knock sensor with the harness. After 4 days, it still hesitates like it did before. Im stumped. Is there any way the engine harness connected that plugs into the knock sensor harness is somewhere corroded where it meets the ECM. cause I Looked in my Chiltons and the Knock sensor is a strait shot to the ECM. Any help or any ideas are most appreciated. Im very stressed out over this and I want my car to be fast again. Thank you
Old Jun 23, 2003 | 06:55 PM
shavedmax's Avatar
see if you can have someone with an obd2 scanner check out the car. most will show you o2 sensor readings, if it fluctuates, wiring and sensors are "supposed" to be good
Old Jun 23, 2003 | 08:25 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
you don't need an OBD reader, just run the self diagnostic from the Chiltons/Haynes manual, it'll tell you the same thing a reader would. and will throw the proper code if its not working right. I don't even think our cars are OBD2 to begin with??
Old Jun 23, 2003 | 09:36 PM
J93MaximSE's Avatar
the thing is, it throws a 55 code, which means nothing wrong. Im just still way confused as to why it worked one day and didnt work the next???
Old Jun 24, 2003 | 04:47 PM
shavedmax's Avatar
i think ours are obd only, but obd 2 will work on ours and will read what the o2 reading is, wether it fluctuates, etc. by running a diag you only get a code
Old Jun 25, 2003 | 09:03 AM
J93MaximSE's Avatar
so where can i find someone with it??? like a dealer or any repair shop?? you say it only reads O2 stuff so do you think that my lack in power has to do with my o2 sensor??? please explain a little more if you could. thanks
Old Jun 25, 2003 | 10:45 AM
DA-MAX's Avatar
nope, there is an A/F monitor built into the ECU self-diagnostic as well...it uses the green/red lights to show A/F ratio, I think its Mode I or II, you have to check the Haynes
Old Jun 25, 2003 | 10:53 AM
J93MaximSE's Avatar
so what do i look under in the hanes?? how to do a self-diagnostics test?? and if so is the A/F thing in there also??
Old Jun 25, 2003 | 11:07 AM
DA-MAX's Avatar
look in the index...dunno the page off hand. its in the part that descibes all the sensors and EGR and IACV stuff
Old Jun 27, 2003 | 11:58 AM
J93MaximSE's Avatar
well i did the self-diagnostics and it shows that my o2 sensor is bad. so where can i pick one up for a reasonable price?? the dealer wanted 194 bucks
Old Jun 27, 2003 | 12:39 PM
DA-MAX's Avatar
check the General or 3rd gen For Sale Forum....AKAICEBERG was selling NTK OEM replacement O2s for under $60 if I'm correct!
REDinLV
Aug 15, 2024 12:30 AM
bigdogsteve
Jan 31, 2018 04:18 PM
sliptap
Sep 30, 2015 05:57 AM
jaydot901
Sep 29, 2015 01:18 PM
