Location of door lock timer
Old Jun 25, 2003 | 06:54 AM
maxmizd27's Avatar
People have said it's to the right of the steering column. Does this mean the dash panel where the rear window defogger switch is? Can someone clarify? Thanks.
Old Jun 25, 2003 | 07:42 AM
D-sta's Avatar
Well you have to take apart the under panel under the steering column, to be more specific the big piece that surrounds the fuse cover lid. Once you remove all the bolts it will come down. You don't have to remove the defogger switch only the panel. Once its out look at the right side of the steering column and you will see a grey box and when you remove it, it should have a sticker that says "door lock timer". Good luck!
ef9
Sep 29, 2015 11:29 PM
johnaschon
Sep 14, 2015 04:29 PM
Hailstatejig
Sep 2, 2015 06:52 AM
