strange sound at high RPM
Old Jun 25, 2003 | 07:06 PM
Cliff Clavin's Avatar
Way out West
I have been hearing a strange sound when I wind out my car. It is a "whoosh" sound that happens sometimes when I'm over 4,000 rpm and virtually every time I shift at high rpm.
Has anyone else had this happen? It seems to be drawing some power at the upper end, too when it makes the sound. I think it sounds like some kind of blowoff (that's not right, but that's what it SOUNDS like) It definitely doesn't sound good.
thanks for your input,
chris
Old Jun 25, 2003 | 07:08 PM
Way out West
ALSO
it sounds like it is coming from the passenger side of the engine compartment. Definitely in the right front somewhere.
Old Jun 26, 2003 | 12:47 PM
Way out West
anyone???
Old Jun 26, 2003 | 01:06 PM
Life2daMax's Avatar
WhoosH!...
Old Jan 24, 2005 | 05:11 PM
MrGone's Avatar
That would be your AC
and by AC, I mean BOV
Old Jan 24, 2005 | 06:06 PM
andy044's Avatar
RWD bolt-on conversion?
WOAH THIS ONE GOT DREDGED UP FROM THE DEAP
maybe exhaust manifold leak?
how are your gaskets?
...or someone put a turbo in when you were sleeping
Old Jan 24, 2005 | 06:38 PM
Hectic's Avatar
oh come one..it's the sound of you breaking the sound barrier...
Old Jan 24, 2005 | 07:21 PM
HTPerformance's Avatar
VI manifold change?
Old Jan 24, 2005 | 07:42 PM
505max94se's Avatar
I get a sound similar to that because I have a cai.
When I punch the gas when it's idling or when I shift a certain way, it'll make a cool woosh sound. Also if you push the gas just right while diving it'll make a whistling sound that's similar to a turbo spooling.
The woosh sound I have is just a large gush of air being sucked into the motor when the throttle body opens. And the whistling sound is just air passing over the throttle body plate when it's at a certain angle.
Most everyone probably has experienced this already.
Old Jan 24, 2005 | 08:11 PM
Alex_V
Thats what I thought. I love that sound.
~Alex
Old Jan 24, 2005 | 08:14 PM
MrGone's Avatar
Originally Posted by 1992maxman
VI manifold change?
dubya tee eff?
its his AC
Old Jan 24, 2005 | 08:23 PM
sara92max's Avatar
Originally Posted by Red92MaxSE
ALSO
Check the vaccuum hoses from the power valve actuator and the surge tank...(runs behind the upper plenum) It could be leaking and not operating the power valve inself in the upper plenum... most likely were the two hoses connect to the surge tank...
Old Jan 24, 2005 | 08:48 PM
Bill Brasky's Avatar
Seperated at Birth?
he's replaced his USDM motor with a JDM DORIFTO GTR TT NAWZ motor since then and now.
Old Jan 24, 2005 | 09:20 PM
MrGone's Avatar
It doesn't matter, he still has his stock AC compressor and still has the noise.
I get teh cookie
Old Jan 24, 2005 | 09:26 PM
Way out West
yeah. that's it
Mar 12, 2020 12:06 AM
jfl330
Sep 4, 2015 01:44 PM
dcardello
Sep 3, 2015 11:44 PM
