Changing the manual tranny fluid on my 92 SE
Old Jul 2, 2003 | 09:16 AM
Mizeree_X's Avatar
Getting back to his roots
I have a couple questions about changing the gear oil on my 92SE. Looking at the FSM, the picture depicting the filler plug is vague at best. I got under the car and checked it out, but there doesn't seem to be a clear choice for the drain plug. Can someone describe its location for me, or take a picture? The other question is that, not having dealt with high weight lubricants before (75W+), I was wondering if the old fluid is going to come out easily, or if I have to get it really hot and then drain it immediately. Will I need an extra qt of new fluid to "push" any remaining fluid from the casing? Thanks for any advice.
Old Jul 2, 2003 | 10:08 AM
Jeff92se's Avatar
I'm needing a caw
My sticky post w/ the chilton's online.
Old Jul 2, 2003 | 12:52 PM
Mizeree_X's Avatar
I own a Chilton's and a FSM. Both use the same vague illustration I have scanned and attached below:
I was just wondering if someone who has done this already can clarify which bolt that is, since there are half a dozen in that general area.
Old Jul 2, 2003 | 01:26 PM
Jeff92se's Avatar
I'm needing a caw
Those pictures are correct. Once you get down there, you will see it. The fill plug is the only one that looks like that. It's fits a 1/2" drive wrench
pktaske
May 6, 2016 07:49 AM
captchaos
Mar 15, 2016 12:18 PM
pktaske
Sep 4, 2015 08:40 AM
dcardello
Sep 3, 2015 11:44 PM
Lowered_a33
Sep 1, 2015 07:49 PM
