" Ah Shi?
Old Jul 11, 2003 | 12:37 PM
MONSTERMAX's Avatar
" Ah Shi?
The other day I Attempted unlock my door and my key broke in it. Does anyone have any ideas of how i can get the remaining piece of the key out without going through the trouble taking the door apart. Any advice would be helpful. Thanks
Old Jul 11, 2003 | 12:42 PM
Jeff92se's Avatar
I'm needing a caw
Superglue?
Old Jul 11, 2003 | 12:45 PM
nubiannupe's Avatar
OG Maxima.org Member
Originally posted by Jeff92se
Superglue?
....and a reeeeaaaalllly steady hand! Or you can possibly use a pick set combined with some tweezers and try to work it out of there. It all depends on how much of the key is showing in the hole.
Old Jul 11, 2003 | 01:08 PM
Matt93SE's Avatar
STFU n00b!
take it to a locksmith before you break anything else. if you don't know how, you're just going to cause more problems by fudging with it.
Old Jul 11, 2003 | 11:07 PM
jakew8's Avatar
Who?
locksmiths use a screw-like threaded pin to get keys out. if you have anything like that, you can try grabbing the key with it. on second thought, get it to a locksmith. it'll only take five mins and save you the trouble.
Old Jul 12, 2003 | 10:33 AM
pkny514's Avatar
hehe. My longer key. The master key is bending now. All because the truck lock is too stiff.
Old Jul 12, 2003 | 11:31 PM
maxdout92se's Avatar
why don't you just use the trunk release button on the driver's door
Old Jul 13, 2003 | 11:33 AM
pkny514's Avatar
yep, thats what i do.
I finally found out what those ***** on the side of the seat do. I was always afraid to tamper with it.
Old Jul 13, 2003 | 11:43 AM
Dielaughing's Avatar
go-go AAA membership!!! use a pro, save yourself the stress.
Old Jul 27, 2003 | 02:43 AM
DARHAW-MAX's Avatar
YGTBSM
Old Jul 27, 2003 | 06:09 AM
shavedmax's Avatar
Re: " Ah Shi?
i have 2 handles in black with matching keys if you want them. the only thing that will suck is that the ignition key will be different
Old Jul 27, 2003 | 07:04 AM
MaDMaX024's Avatar
is there any way to repair the fudged door locks? i dont care about the trunk as i have the popper on the drivers door but its impossible to open the passengers door, and the drivers takes alot of effort and i'd like to stay away from breaking my key.
Old Jul 27, 2003 | 07:18 AM
shavedmax's Avatar
wd 40 the locks and see it it helps, if not change them, or shave them!
Old Jul 27, 2003 | 01:25 PM
Agamemnon's Avatar
What shavedmax said, though it's too late now. Next time you can't turn the key, don't force it. Spray some WD40 or other lubricants through the key hole, and let it work its magic.
And next time, never, ever force a lock with more force than neccessary. It's likely to do more harm than good. Though I myself occasionally need to follow this advice as well.
Old Jul 27, 2003 | 06:01 PM
MaDMaX024's Avatar
i dont force it, i wiggle it around until it works..one night after work i was outside my car in the dead of winter, 20 degrees, windy and snowing, car wouldnt open for like a half hour..that was obnoxious...yesterday it wouldnt open at all..whatever, i'll try to get it fixed before i drive it again.
Old Jul 27, 2003 | 10:47 PM
Agamemnon's Avatar
Well, if it happened in the winter... In severe cold weather, metal becomes brittle and easy to break. Plus locks have tendency to froze together (won't turn) compounding the problem.
That's why I put on keyless entry on my Max! First thing I did after buying it. Just don't want to fiddle with the key in -30 weather common here in Minnesota...
Old Jul 28, 2003 | 09:49 AM
negreenfield's Avatar
tip the car on it's side, it'll fall out...
i thought they had a tool or some kind of kit at most auto stores for this kind of thing? have you checked at one?
Rogo02SE
Mar 15, 2003 01:43 PM
99Maxima5sp
1/4 and 1/8 Mile Racing
32
Mar 12, 2003 08:41 PM
Little95Max
Feb 18, 2003 11:27 AM
ngthing
Oct 19, 2000 12:27 PM
