Homebrew CAI / MAF Relocation w/Photos
Old Jul 15, 2003 | 05:56 PM
negiti's Avatar
At the behest of crazy4maxima:
http://drivebug.com/maf-cai/maf-cai.htm
Enjoy,
-Joe
Old Jul 15, 2003 | 06:09 PM
crazy4maxima's Avatar
nice! hehe.. now try to get that filter into the fender and run tt as a cai, and put some heat sheild to keep the tube cool...
Old Jul 15, 2003 | 06:26 PM
negiti's Avatar
What I had in mind after moving the filter down/in is setting up a second, larger diamter elbow to fit the base of the filter, aiming forward, with an angled opening. Can we say . . ram air??
Old Jul 15, 2003 | 08:26 PM
probmxstyle's Avatar
You cookin potatos in all the aluminum foil? J/k, i would think that there would be more hot air behind the motor then in the front.?
Old Jul 15, 2003 | 11:01 PM
negiti's Avatar
Works . . well . . and potato salad when you get there. What more could you want?? lol
Old Jul 15, 2003 | 11:21 PM
mtcookson's Avatar
i don't recommend putting the filter down there. when i put mine down there somehow the filter got soaking wet when it rained (and i wasn't even driving it!)
Old Jul 16, 2003 | 06:23 AM
negiti's Avatar
Yeah . . had a problem like that w/an Isuzu Rodeo we had. Ended up building a ram air scoop, using the fog light socket as the mouth of it. At the place where the bend uP took place, I drilled a series of very small holes on the long radius of the curve (back of curve). On rainy days, the air would continue up the the pipe, but the water would become trapped at the bend, and ooze out the tiny holes in the long radius. Constant monitoring confirmed that the K&N filter remained dry as a bone.
Old Jul 16, 2003 | 11:05 AM
mtcookson's Avatar
i would build an air box using sheet metal or something and put it over that hole. that is what i'm planning on doing with mine (somewhat). i also have the e36 conversion so i'm to kind of do a ram thing behind the headlight. i will cover the rear of the headlight with the sheet metal making a sort of scoop and also having the hole in the bottom breath too. that way i can try to keep temps down as good as i can.
Old Jul 16, 2003 | 05:50 PM
negiti's Avatar
That sounds like a greaT idea! Let me know how it comes along.
Just had a Suspension Techniques sway bar <front> put on. It weighs *SEVERAL* times more than the original, and there is quite a difference in uneven pavement handling and cornering. I am going to go back in the morning and see about installing the matching rear sway.
TallTom
57
Oct 14, 2025 05:16 PM
-ReLLiK-
Apr 29, 2016 06:25 PM
Sep 27, 2015 08:37 AM
A32goldylocks
Sep 16, 2015 01:33 PM
ballerchris510
Sep 10, 2015 09:35 PM
