For those Auto-Manual converted owners
Old Jul 23, 2003 | 02:30 AM
Turbo95Max's Avatar
Turtle turtle... Moderator
we juss completeed a lengthy 4 month motor swap and 5speed conversion on a guy's 3rd gen. its a 91 Max with the VG motor. using the auto trans wiring harness. Could anyone provide some insight or info on what wiring and bypass we have to do for the car to crank? basically when we turn the key it doesnt even crank. any help at all would be great...we already have a FSM, for some reason it makes the wiring diagrams make me more confused...my 95 manual seems alot easier to read and understand. thanks alot!
Old Jul 23, 2003 | 04:16 PM
Shadow1198's Avatar
Large Member
I know EXACTLY what the problem is. Sorry for the late reply. Let me get some pics of it. It's called the "Inhibitor Relay (A/T Model)" in the Haynes manual, and it is located in the relay box in front of the battery. Basically, you have to remove the relay and put a jumper in to disable it. Without this jumper, the car will not turn over at all.
Old Jul 23, 2003 | 04:19 PM
KLoWnPR109's Avatar
What do you mean by putting a jumper into? Did you ever take pics of how you bypassed that relay too? Thanks
Old Jul 23, 2003 | 04:30 PM
Jeff92se's Avatar
I'm needing a caw
http://www.cybrrpartspro.com/Chilton...61CH07_13.HTML
Old Jul 23, 2003 | 04:47 PM
Shadow1198's Avatar
Large Member
Well, I put the jumper where the relay was in order to bypass it. I'm going to try and get the pics in a few minutes (I hope this stupid digital camera works right!)
Old Jul 24, 2003 | 02:03 AM
Turbo95Max's Avatar
hey
yea thats what i had to do for my car but we swapped out the auto trans harness. another 5speed conversion we did, we had to jumper something on the wiring harness....cant rmeember what tho...
Old Jul 24, 2003 | 10:17 AM
KLoWnPR109's Avatar
probably the starter inhibit. There are three wires coming outta it, brown black and kinda a tan color
Old Jul 24, 2003 | 10:24 AM
surfermax92's Avatar
I dunno if it makes a difference for this Matthel, but the car is a '92 and the FSM is for a '91
Old Jul 24, 2003 | 10:44 AM
KLoWnPR109's Avatar
Not if it's a VG.
Old Jul 24, 2003 | 10:45 AM
Matt93SE's Avatar
STFU n00b!
that shouldn't make any difference... the 91 and 92 are the same things, unless you're looking at VE/VG.
I'm assuming it's the circuit that says "Hey! I'm not in park! don't start me!".. probably more commonly called a starter inhibitor circuit.
Old Jul 24, 2003 | 10:52 AM
KLoWnPR109's Avatar
I'm a little confused. What is running a jumper? Same thing as bypassing? For the starter inhibit, I've just got those wires running back into each other.
Old Jul 24, 2003 | 11:52 AM
Turbo95Max's Avatar
you have all 3 wires connected to each other? juss wnated to clarify...thanks
Old Jul 24, 2003 | 02:33 PM
Michael's Avatar
Back in a 3rd Gen.
Jumper= a connector (just a wire is fine) used to connecting 2 wires together that are otherwise not connected...shorting the wires toghether.
doctorpullit
Oct 28, 2019 10:58 PM
D Mason
Jun 21, 2016 04:43 AM
bernyp
Oct 2, 2015 10:10 AM
09maxshawn11
Sep 30, 2015 10:28 AM
sliptap
Sep 30, 2015 05:57 AM
