Power steering belt troubles
Old Jul 24, 2003 | 08:04 AM
raeqwon28's Avatar
I have replaced the power steering belt about 2 or 3 times and every time it will run alright and then the belt will start slipping off the pulley. I have went by the manual word for word and it still rubs against the alternator belt. Could there be something wrong with the pulleys or do I need a wheel alignment ?
Old Jul 24, 2003 | 08:22 AM
CandiMan's Avatar
Say Candyman 5 times
Re: Power steering belt troubles
Originally posted by raeqwon28 I have replaced the power steering belt about 2 or 3 times and every time it will run alright and then the belt will start slipping off the pulley. I have went by the manual word for word and it still rubs against the alternator belt. Could there be something wrong with the pulleys or do I need a wheel alignment ?
No you dont need a wheel alignment. You need to closely inspect the pulley and brackets on your p/s pump and alternator. Make sure the p/s pump or alternator brackets are not broken which will cause either belts to be miss aligned and rubbing on the other.
lowpost99
Oct 26, 2025 06:53 PM
markevans999
Oct 25, 2015 08:27 AM
2kmaximel
Sep 10, 2015 08:13 AM
SusieQQ
Sep 9, 2015 12:14 PM
