maxima airbags!!!
Old Jul 31, 2003 | 09:34 AM
maxda92gxe's Avatar
maxima airbags!!!
i dunno if this is a stupid question..but i thought all maxima's had airbags??..becuz today when i went to call the auto shop to order my axle..he says do you have airbags and i was like yeeah!! and he goes are u sure..u better make sure before u order and then he just hung-up!!..what an *******!!
Old Jul 31, 2003 | 09:47 AM
jaguax's Avatar
I don't think the older maximas had them like 89 and 90. Don't quote me on that though.
Old Jul 31, 2003 | 09:58 AM
DARHAW-MAX's Avatar
Look on your steering wheel. If the cruise control buttons are on the side, then you have an airbag. If the buttons are embedded in the wheel itself, then NO, you do not have an airbag. Also, on your sun visor, there should be a sticker of some sort warning you about the possible dangers of SRS.
Old Jul 31, 2003 | 10:01 AM
Pooge's Avatar
93 they went to airbags.
Doug
Old Jul 31, 2003 | 10:12 AM
DARHAW-MAX's Avatar
My '92 SE has airbags also.
Old Jul 31, 2003 | 10:38 AM
GRNMAXDMON's Avatar
89-91SE/GXE = no airbags
92-94SE/GXE = airbags
Old Jul 31, 2003 | 01:55 PM
Tim93se5sp's Avatar
Correction:
89-91 no airbag
92 airbag optional (at least on the SE- may have been standard on the GXE)
93+ airbag
Old Jul 31, 2003 | 03:25 PM
GRNMAXDMON's Avatar
eh close enough
Old Jul 31, 2003 | 03:26 PM
jaguax's Avatar
Originally posted by Tim93se5sp
Correction:
89-91 no airbag
Dunno about that, there is a 91 for sale here with driver side airbag: http://www.carsearch.com/701691.htm
Also on Ebay there is an airbag for 91-94 Maximas.
Old Jul 31, 2003 | 04:14 PM
pezking4's Avatar
I have the airbag option on my 92 SE, but why would it matter if you were trying to order axles? Maybe he meant to ask about ABS.
Old Jul 31, 2003 | 04:35 PM
maxima2k2's Avatar
wow i thought all the 3rd gen model came with airbags. isnt it mandatory that all cars come with driverside airbags at least?
Old Jul 31, 2003 | 04:47 PM
jakew8's Avatar
Who?
not back then it wasn't
Old Jul 31, 2003 | 05:30 PM
maxda92gxe's Avatar
what is abs..anti-lock brake system???...how do i know that!!
Old Jul 31, 2003 | 07:11 PM
pezking4's Avatar
http://www.cybrrpartspro.com/Chilton.../89619g13L.gif
I noticed on VE's if you have ABS your coolant overflow resevior is located near the battery, and if you don't have ABS, it is located on the left side of the engine bay.
Is it the same with you VG guys?
Old Jul 31, 2003 | 07:17 PM
GRNMAXDMON's Avatar
i guess so???
Old Jul 31, 2003 | 07:50 PM
Mizeree_X's Avatar
Getting back to his roots
I am guessing that they say there are airbags for 91-94 maximas because the first 92 maxes were manufactured in 91.
Old Aug 1, 2003 | 01:37 AM
DARHAW-MAX's Avatar
The difference between ABS and not ABS axles are the the ABS teeth for the sensor. On ABS axles, there are teeth that look like gears that run close to a magnetic sensor. It is this sensor that detect which wheel is locked up and engages the ABS accordingly. Very important.
How can you tell if you have ABS? Look in the engine bay (can't remember if it is the left or right side) and look for a metal box with four metal lines coming out of it. This is your ABS cylinder. If you are unsure, go to a local Nissan service shop and have them identify it for you.
Old Aug 1, 2003 | 12:35 PM
GRNMAXDMON's Avatar
the ABS is on ur left hand side when ur facing the motor.
Flores94
Aug 13, 2015 01:17 PM
cmpowell86
Aug 10, 2015 12:35 AM
kirkhilles
Aug 8, 2015 10:53 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
