screw on the ecu
Old Aug 3, 2003 | 08:05 PM
chchmax's Avatar
screw on the ecu
hey guys, what position should this screw be in, and what does it affect if adjusted? reason i am asking, is because i checked mine for the first time, and its all the way anticlockwise. Is this normal?
Sorry if this is a stupid question!
-Scott
Old Aug 3, 2003 | 10:00 PM
Aaron92SE's Avatar
NWP Engineering.com
Re: screw on the ecu
Yes, it's normal. Leave it alone unless you want to run a diagnostic procedure. Get a Nissan factory service manual off eBay if you want to mess with it.
If you turn your ignition to "ON" (don't start motor), turn the screw all the way clockwise, wait 2 seconds, then turn all the way CCW... it will flash a code at you. That red LED will start to blink. If it flashes 5 long and 5 short, then that's code 55 and that means everything is working like it should. I'm not going to list out all the codes, but maybe you can find them with a search. Oh yeah, the search is down. Go figure. Sorry.
Old Aug 3, 2003 | 11:07 PM
MaximaGuy719's Avatar
Re: Re: screw on the ecu
Originally posted by Aaron92SE Oh yeah, the search is down. Go figure. Sorry. [/B]
Why does everybody keep saying this? The search works at the test site.
Old Aug 4, 2003 | 12:26 AM
Aaron92SE's Avatar
NWP Engineering.com
Re: Re: Re: screw on the ecu
Originally posted by MaximaGuy719
Why does everybody keep saying this? The search works fine for at the test site.
Oh, last time I checked the test site was down.
Old Aug 4, 2003 | 12:27 AM
chchmax's Avatar
thats cool, thanks for that aaron92se. The chiltons website has a section on error codes, just enter the code into there and it tells you the problem. Turned out i got a code 55 anyway. Car was real hot, and runing like crap, so i assumed knock sensor, thats why i wanted to check for an error code, but i guess it'll only pull a code if it craps out, not if its just being over sensitive...
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
doctorpullit
Mar 29, 2016 11:08 AM
sliptap
Sep 30, 2015 05:57 AM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
