Air conditioning compressor problem :edit by Jeff92se:
Old Aug 15, 2003 | 01:13 PM
93SE5SPNY's Avatar
Has this happened to you?.......
I was going to make an attempt to recharge my AC and for some reason everytime I turn the blower on it's fine, but when I push the AC button, the engine shuts off!!! It happens over and over.
If I press on the gas pedal to increase the rev's, when I hit the AC button, there is a screeching noise and then I see and smell smoke.
I don't know what it could be, but as long as I don't press the AC button tha car runs fine. I was hoping for some feedback as I don't want to buy a bunch of parts and they are not the right ones.
Needless to say I can't recharge my AC. It's a 93 SE 5SP
I think it might be the compressor, I only hope it's simple. I tried the search to see if anyone has experienced it, but no go.
Thanks a million,
Have a great summer
Ron
93se5spny
Old Aug 15, 2003 | 02:34 PM
Jeff92se's Avatar
I'm needing a caw
It's screeching because for some reason the compressor is not turning. It doesn't screech when it's not on because the clutch is not engaged. It could be a bad clutch on the compressor. But if you been running this unit w/o or low on freon, you could have ruined it. And if you have ruined it, you could have contaminated the rest of your AC components, ie.. dryer/condensor and anything else that runs inline with the freon.
The freon not only makes the air cool, it lubricates the compressor bearings.
Old Aug 15, 2003 | 06:33 PM
dmontzsta
any idea why mine sounds like a BOV when it goes on? sfiiiiiiiiiiiiiishhhhhhhhhhh
Old Aug 15, 2003 | 06:47 PM
Matt93SE's Avatar
STFU n00b!
the clutch is slipping a bit and it makes nasty noises when it engages... mine does that too. signs that it's about time for a new one. $$$
Old Aug 15, 2003 | 08:32 PM
93SE5SPNY's Avatar
Thanks for the help
I kind of figured it was time to replace the compressor. It has been awhile since I ran the AC. It hasn't been on in at least 2 summers and know I am paying the price now.
It it necessary to replace all the parts or just the replace the compresor? I figured that putting freon in it won't do a thing at this point and the cheapest I could find a compressor for is $270.00
Thanks again as always for the help.
Ron
93SE5SPNY
Old Aug 15, 2003 | 09:32 PM
Cliff Clavin's Avatar
Way out West
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2428052807
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2427962030
The first one looks good, but the guy won't warranty it.
The second looks like it fell off of a truck onto the freeway, but he'll warranty it for 30 days.
cheaper than $270...
Old Aug 16, 2003 | 04:47 AM
CandiMan's Avatar
Say Candyman 5 times
Originally posted by Jeff92se The freon not only makes the air cool, it lubricates the compressor bearings.
That's why it's a good idea to run your AC in the winter time for a couple minutes once or twice a month to keep all components lubricated. Not totally needed but it's a good preventive maintenance.
Old Aug 16, 2003 | 09:00 AM
Matt93SE's Avatar
STFU n00b!
Neither of those will work for his car. they're both R12 compressors (note the 89-92 designation on the listing). his '93 has R134a in it. the compressors will "work", but they're not the ones designed for the car.
Old Aug 16, 2003 | 04:08 PM
Way out West
didn't think of that. My bad. Damn environmentalists...j/k
Then just start saving money. Summer's almost over and you have until about next May to come up with the cash
I have to do the same thing. Mine's starting to sound "like a BOV" when I get it over about 5k RPM.
tsi6001
Oct 3, 2022 10:23 PM
MAXSE5SPD
Sep 17, 2022 04:00 AM
intimidator
Sep 5, 2015 07:23 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
egali045
Aug 5, 2015 09:02 AM
