dorr lock timer resolder...
Old Feb 8, 2001 | 07:19 PM
fornimage's Avatar
anybody got the instructions on how to resolder the dr lock timer so that the timer is bypassed. I've opened the timer itself but I don't know exactly which part is exactly the timer to remove. I heard of people do'n this before so any help is well appreciated. Thanks in advance!
Old Feb 8, 2001 | 07:27 PM
Brandon90gxe's Avatar
what is that and what does it do? ive heard its only on the 92's and up but still i just wanted to know what it did...
Old Feb 9, 2001 | 06:42 AM
«§»Craig B«§»'s Avatar
It think you're getting a little mixed up with this. People often take out their clock and replace the capacitors in there to make it work again. As for the door lock timer, I've only heard of one person doing any soldering with it - Matt93GXE. I think he said that he just resoldered all the joints in there and it worked. He didn't bypass it or anything and I'm not really sure that you could or would have any reason to bypass it. Just add some flux and try to resolder all the joints is your best bet.
The door lock timer is on 91+ (maybe 92+) models I think and it just controls the lock and unlocking of the doors
Old Feb 9, 2001 | 07:25 AM
fornimage's Avatar
Yeah... I did get confused because I got the impression that the dr lock timer could be completely bypassed. I'll try resoldering all the joints and see what happens. Thanks!
Old Feb 9, 2001 | 10:17 AM
Matt93SE's Avatar
STFU n00b!
Nooooo, you don't change or bypass anything.. as Craig said, all I did was resolder all the connections. just grab a soldering iron, roll of solder, and go after it.
be careful not to add too much solder and start gluing the thing together! (but if you know how to solder, you've got enough sense to know better than that.)
BTW, took me about 45 min to do the entire thing from start to finish.
Old Feb 9, 2001 | 11:16 PM
93 SE's Avatar
when i shut off my engine and close doors my car should automatically lock after 30 seconds or so right..also engaging factory alarm...well my car doesnt do that anymore so gotta resolder it right? also i have an aftermarket alarm and when i use to arm and unarm alarm my brake n cornerlights would blink now they dont
Old Feb 10, 2001 | 12:28 PM
kaleb's Avatar
No, the doors do not automatically lock.
The door lock timer is a timing unit that works with the door actuators and the digital touch entry system (if you have it). It's like an elaborate relay I suppose.
You know you need to replace it if your door locks start to work on and off or if they stop working completely. I discovered this problem a year or so ago when I was sick and tired of my locks doing wierd stuff. So I went to work and started replacing stuff :0). The door lock timer was the first unit I saw, and it worked the first time. Nissan doesn't even have it in a TSB.
James92SE
142
Jan 2, 2024 09:23 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
ajahearn
Sep 19, 2015 03:03 PM
johnaschon
Sep 14, 2015 04:29 PM
