has anyone changed the front struts themselves?
Old Feb 9, 2001 | 04:18 PM
block's Avatar
mine are shot and I was thinking of changing them myself. anyone run into any problems with this?
Old Feb 9, 2001 | 04:54 PM
DanNY's Avatar
Ad·min·is·tra·tor
pretty much straight forward. bottom two bolts. top 3 nuts and pull them out. get a spring compressor and compress the springs. once that's done take off the top bolt and the assembly should separate. make sure u know how the top plate goes..(position).
there's more to it..but that's a general idea.
Old Feb 9, 2001 | 05:39 PM
brubenstein's Avatar
The springs are long, and need to be compressed quite a bit. Make sure you span 4 coils with the compressor, or you won't be able to compress it enough.
Make sure you get new strut boots also.
Old Feb 9, 2001 | 07:59 PM
thebull's Avatar
just make sure you dont take the bolt off the strut that compresses the spring when the struts are still on the car. i did it just to see if i could take the strut and spring apart without using the spring compressor and that spring shout out like a motha-f**ka. lol. thought i was gonna get killed.
Old Feb 9, 2001 | 08:06 PM
DanNY's Avatar
Ad·min·is·tra·tor
ouch...you should be lucky that you're alive.
MaxStock
Aug 14, 2015 10:01 PM
Balkins
Aug 12, 2015 06:39 AM
Greenmaxspeed
Aug 8, 2015 12:39 PM
laparka66
Aug 6, 2015 09:36 AM
RealityCheck
Aug 5, 2015 06:18 AM
