abs or posy??
all SE models do NOT come with ABS
look on your dashboard at the idiot lights, if there is one for ABS, then you have it; if not, then you dont
also, you can look under the hood, if your coolant reservoir is in front of your battery then you have ABS; if it's behind the pass side headlight by the windshield washer fluid, then you dont have ABS
posy? not sure what that means; maybe limited slip differential? to check for that, look at the small silver plate attached in the middle of the firewall and it will tell you your tranny code. If it ends in a 'V' then you have LSD
You can get axles from Pepboys or wherever for probably $70. raxles.com has better quality axles for $120ish-150 depending on which side.
Pied
Sep 26, 2015 03:29 PM
