t50h Torx screw and screw driver
Old Aug 25, 2003 | 06:42 PM
JimmyC's Avatar
I'm trying to take off the airbag and there's a torx screw on it. I was told to purchase a T50H screw driver, but I can't seem find one. Doesn't anyone know where I can get one? Also I was told to discard the screw after I take it out. If I discard it, where can I get a new one? Thanks
Jimmy
Old Aug 25, 2003 | 06:44 PM
subs1000w's Avatar
if all you need is a t50 torx you could get one at any hardware store or like autozone but im not familer with t50h unless its like security torx or somthing
Old Aug 25, 2003 | 06:48 PM
JimmyC's Avatar
Yeah, it is a security torx. I tried about 10 hardware stores and also tried autozone, strauss auto... etc, but no luck. Thanks for the suggestion.
Old Aug 25, 2003 | 06:58 PM
Matt93SE's Avatar
STFU n00b!
Sears makes some, but the set I've got only goes up to T30. check sears and see if they've got a bigger one and also try Fastenal. They're a fastener supply place, and may be able to get them.
if that doesn't work, give the dealer a shot.
Old Aug 26, 2003 | 09:13 AM
Jeff92se's Avatar
I'm needing a caw
I've gotten Tamper Resistant Torx bit set from my local auto store. Sears sets only go up to a T30 like Matt said. These are different than normal torx as these have a big stud right in the middle so the torx has to have a hole in the middle. I got a cheap set(the torx aren't torqued down very tight anyway) from "Shucks". But most any store ie.. autozone/pep boys/etc should have them. Thing is the stupid lugnuts that work there probably don't know if they have them or not so you have to look on your own. Look carefully in the tool section
user 11122324
42
Jul 18, 2022 03:35 PM
doctorpullit
Mar 29, 2016 11:08 AM
BobTX10
Oct 7, 2015 08:43 AM
sliptap
Sep 30, 2015 05:57 AM
Noela
Sep 26, 2015 08:22 AM
