engine control module '89
Old Sep 3, 2003 | 06:02 AM
io-doc's Avatar
My '89 is either dead or comatose. It won't idle, but will run at high RPM. Then it stalls when you back off the accelerator. My mechanic says the engine is flooding itself, but fuel pressure reg, plug wires, cylinder pressure, injector sensors are all OK. He says it's in the 'computer' (i.e., ECM). He did not check the rotor or distributor. He found no error codes, but could not check the actual ECM. I do not want to do the dealer thing and install a new ECM. Any ideas what can cause the injectors to flood? Can I get a used ECM and plug it in to see if that does it? Any advice to get it running again is appreciated.
Old Sep 3, 2003 | 09:28 AM
subs1000w's Avatar
that could be the idle air control valve i would check that first before replacing the computer but if you want to replace the computer heres one for a good price http://cgi.ebay.com/ebaymotors/ws/eB...category=33596
Old Sep 3, 2003 | 01:55 PM
DARHAW-MAX's Avatar
ECM? Hmmmm. You may want to check some other items first. I have never heard of the ECM going bad. Like Subs said, you may want to check the IACV and some vacumn hoses. While checking on e-bay, check into a FSM. It will cover all of these kinds of problems.
derekinthez
Nov 13, 2022 04:00 PM
Starrider
Dec 18, 2015 04:43 AM
fastcarny
Oct 6, 2015 10:42 AM
carid
Sep 9, 2015 05:06 AM
