Posible?
Old Sep 18, 2003 | 10:00 AM
98RACE's Avatar
Posible?
Was it posible for a 94 GXE to come with the DOHC motor?
Was it an option?
Dave
Old Sep 18, 2003 | 10:11 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
no
(arrrgh..10 character rule )
Old Sep 18, 2003 | 10:17 AM
DARHAW-MAX's Avatar
Was it an option?
Dave
Check it out:
Specs and Features
Old Sep 18, 2003 | 12:05 PM
98RACE's Avatar
Ok thanks for that I got another question.
If I wanted to swap the DOHC in would I need a trans or are the SOHC and DOHC the same?
Could I just swap the head?? <--maybe a dumb question or not.
Old Sep 18, 2003 | 12:09 PM
DA-MAX's Avatar
different trannys
and no you can't just swap the heads
use the SEARCH
Old Sep 18, 2003 | 12:21 PM
Jeff92se's Avatar
I'm needing a caw
Would you be able to if it were possible?? And if you would, consider how it would be done and explain it to us. Because if you aren't really mechanicly inclined enough, why ask? Same goes to any mechanic that you might hire to do the same.
Old Sep 18, 2003 | 12:23 PM
LittlePiggie's Avatar
think about this:
the DOHC has two cams, so the head is BIGGER than the SOHC...
Old Sep 18, 2003 | 12:25 PM
Jeff92se's Avatar
I'm needing a caw
That's not really the issue. Issues are chains vs belts, front covers,ignition issues, wiring issues, lubrication issues, and selling issues when one finally gives up.
Originally Posted by LittlePiggie
think about this:
Old Sep 18, 2003 | 12:26 PM
98RACE's Avatar
Sorry for the dumb questions but I have no experiences with these car or with web boards?
What I found out is it may be possible to use the tranny but I will need the ecu.
If someone help me complete what I will need that would be helpful.
Old Sep 18, 2003 | 12:29 PM
Jeff92se's Avatar
I'm needing a caw
If your current engine is working properly, don't mess with it. If you want to convert from auto to 5-sp, fine. That is a doable mod.
Old Sep 18, 2003 | 04:42 PM
98RACE's Avatar
Im just looking for some options for my brother. He does not have the car yet but he will be picking it up on saturday.
A swap is out of the question now because I was looking a prices and for an extra 30hp its not worth it. Well just do some work to this motor, nothing major just some bolt on stuff for now.
Q. What would be the best intake set up? (make)
Also I was reading advanced timing what would be the best degress to set it to?
Thanks for your help.
Old Sep 18, 2003 | 04:57 PM
98RACE's Avatar
I did a search and found 20 degress is the most you want to go. Do you have to run high octane so you dont get spark knock?
Old Sep 18, 2003 | 05:18 PM
Matt93SE's Avatar
STFU n00b!
that should have been right there next to the statement saying to run 20 degrees, yes.
robsterzallan`
78
Aug 23, 2010 10:09 AM
hotmax97
19
Jan 28, 2004 12:05 AM
Neeferea
Nov 1, 2003 06:17 PM
jswconsult
Jun 5, 2003 07:48 AM
turbocivicex
Oct 9, 2002 08:55 AM
