I just got a WP 2.5" Y-pipe and I wanted to know what kind of cat converter would I need? I was going to order the CarSound universal ones that they sell on Ebay but I wanna be sure am I getting the right one. Which is the right converter to get ?
Quote:
I heard they were overpriced pieces of junk. If you want to spend $180 for a hi-flow cat get the metallic substrate one WSP sells. My $0.02.Originally Posted by gowirelessnj
i was looking at random technologies
Dont forget the cat back + muffler.
Quote:
No.Originally Posted by KRMaxima21
Quote:
Originally Posted by jaguax
You can still use the stock converter with the warpspeed Y right?
You can use the stock cat if desired, you can order a carsound cat from warpspeed for $107.00 shipped. I've had it and no problems with it.
"optimum performance with minimal reduction of horsepower" Why do you want the "Y" pipe?
Quote:
Why?
Originally Posted by Red92MaxSE
Did you say you can't use the stock cat with a Warpspeed y-pipe?Why?
Arent they different sizes in diameter? Won't the exhaust leak?
Quote:
It does work with the stock cat then. All the instructions I have read never mentioned buying a new cat. They just said to take the old pipe off and the new one will bolt right on.
So why did you say no? O_o
So you CAN use the y-pipe with the stock cat, it is just PREFERRED that you get a less-restrictive cat and cat back exhaust, for "optimum performance."
I want the y-pipe because mine is shot and warpspeed is cheaper than a oem one (by about 1/2). My cat and muffler are still fine. When they go out, I will probably replace them, too.
damn guys all you need a cat delete pipe then you are on you way to true performance
but if you have inspection comming up i wpuldnt get it untill you pass.
How much was the Warpspeed?Originally Posted by Red92MaxSE
So you CAN use the y-pipe with the stock cat, it is just PREFERRED that you get a less-restrictive cat and cat back exhaust, for "optimum performance."I want the y-pipe because mine is shot and warpspeed is cheaper than a oem one (by about 1/2). My cat and muffler are still fine. When they go out, I will probably replace them, too.
Why didn't you just go stock aftermarket?
I sell the stock replacement for $150
warpspeed is $215 shipped from them. I figured that I might as well upgrade. From what I understand, the stock y-pipe is the most restrictive part of the 3rd gen exhaust.
Then, later down the road I will probably put in a less restrictive cat or test pipe, and an after cat system.
not a bad deal. I'd probaly do the same.
Actually I was gonna do the same when I thought my Front pipe was bad. Turns out it was my Cat-back.
I'm gonna have my local shop bend up a custom pipe with no muffler just a resonater (sp?).
I like the noise just wanna move it back a bit
Quote:
It won't leak since the stock cat and y-pipe meet up at a flange where there is a gasket in between and also the warpspeed comes with new gaskets.Originally Posted by e_is_chillin
Haha david, is that sig pic photoshopped or a movie scene?Originally Posted by David89Max
