headlight not workin properly
Old Sep 26, 2003 | 11:22 AM
wicked_ryder's Avatar
hey guess....i got a problem with my headlights. everynight for the past couple days now, i noticed my driver light was out, upon openin the hood...i touch the wiring an it lit back up an was workin again, but now i havta do that everynight. it seems like its towards the back of the bulb..the harness, could it be loose? i do have apc hyper white bulbs in there, could that be the cause????
anybody have a similar problem or a way to fix this...gettin very annoying!!!
thanks
Old Sep 26, 2003 | 11:29 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
sounds like a burnt harness...take the bulb off and look at the electrical connector, if it doesn't look normal(burnt, charred, etc.) than you'll need a new one
what wattage were the APC bulbs?
Old Sep 26, 2003 | 11:34 AM
i cant remember of hand...but there high....180/100....something high like that. but the shop were i got it at, the dude said it wouldnt burn it out and would be fine!!!
Old Sep 26, 2003 | 11:35 AM
how bad is it changing the harness if that is the problem? expensive?
Old Sep 26, 2003 | 11:44 AM
DA-MAX's Avatar
heh, that dude who sold them to you is an idiot, people do anything to sell products. any bulb higher than the stock wattage usually destroys the harnesses on these cars.
putting on a new harness is pretty simple...they are like $8 at Nissan and you just cut off the old one and re-wire in the new...3 wires thats it.
Old Sep 26, 2003 | 11:49 AM
DA-MAX......thanks alot buddy, i was about to get worried here....i already need ta get broken studs replaced for an annoying exhaust leak. the guy who sold them to me, i will give him a call an see whats up. i'll look into repairing this, an thanks again!!
Old Sep 26, 2003 | 09:06 PM
AscendantMax's Avatar
yet again i have to recommend Sylvania Silverstars. uses stock wattage so it won't burn your harness and puts out nice white light.
Old Apr 4, 2006 | 09:27 AM
'90Maxima's Avatar
Re-wire with thicker wires if your goin to use higher wattage bulbs.
Old Apr 15, 2006 | 12:07 PM
cachejob's Avatar
i have a headlight issue too. since i'm not allowed to post a new thread until i've replied to 15 posts i'm going to have to tack it onto the end of your thread. i'm almost certain the DTRL (day time running light) module is toast. none of the running lights come on, neither low beam, and only the passenger high beam is working now. used to be that the left headlight would be on with running lights, then would go off and right headlight would come on with low and high beams. all fuses check out. swapped bulbs with no difference. haven't checked voltage at the plugs yet but both are fed from the DTRL module and since the bulb swap made no difference i doubt there's power getting to the driver's side headlight plug. the DTRL module is a pricey enough part that i'm looking for a way to bypass it. i figure that since the 3rd gen maximas in the states didn't have DTRL there must be a way around it. i've tried removing the module, but no difference. i've seen references on later models to removing a fuse, but i don't think there's a DTRL specific fuse on the 3rd gen. any input is appreciated. sorry for the threadjack, though i think you pretty much had your question resolved.
Old Apr 15, 2006 | 03:13 PM
Maxima Man's Avatar
These cars don't have day time headlights!!
Old Apr 15, 2006 | 04:05 PM
cachejob's Avatar
Canadian ones do... it's a 92 SE. the running lights are temporarily working again, but neither lowbeam and 1 high beam still don't work. i'm sure jumpering some of the wires going into the control unit will disable the DTRL but i don't want to accidently connect the wrong 2 and fry the ECU
Old Apr 15, 2006 | 06:00 PM
Greeny's Avatar
¯\(°_o)/¯
Canadian model 3rd gens have daytime headlights....
Old Apr 17, 2006 | 08:11 AM
cachejob's Avatar
bump to the top. still hoping for a way to bypass/disable DTRL module.
Old Apr 20, 2006 | 07:03 PM
cachejob's Avatar
maybe i'm just outta luck
Old Apr 21, 2006 | 01:21 PM
old thread...
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
knight_yyz
Nov 1, 2015 01:34 PM
trsandrew
Oct 25, 2015 02:47 PM
Noela
Sep 26, 2015 08:22 AM
