odd problem this morning
Old Oct 1, 2003 | 07:59 AM
Menel's Avatar
1992 Maxima SE
around 11am i was gonna run to the gas station
started the max and it didn't wanna go above 1500rpm. which meant a slowly accelerating drive to station
idled really really rough when stopped at signs or light. and then at one light while sitting it smoothed out, so i reved it up and it did fine, and was fine for the rest of the short trip.
what just happened? never experienced that before
Old Oct 1, 2003 | 08:03 AM
Matt93SE's Avatar
STFU n00b!
might be a problem with the MAF.. possibly some water or oil got on the wire inside and took a while to cook off, or the connector itself is not being cooverative.
Old Oct 1, 2003 | 08:04 AM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
maxima gremlins. j/k that could be one of many things causing that issue. check the TPS (throttle position sensor) and the MAF (mass air flow) for proper operation. a multimeter will help you with this. Could be numerous other things but it very hard to tell with out hearing it or seeing it.
Old Oct 1, 2003 | 10:29 AM
5spdmaxx's Avatar
thats your maf sensor i know because i changed it twice on both maximas i own
Old Oct 1, 2003 | 09:08 PM
Menel's Avatar
1992 Maxima SE
thanks afraid of that, have had other symptoms of MAF failture for the past few months......such as when accerlating or even crusing will "stall" to idle but not cut off the engine. just become unresponsive for a few seconds
Old Oct 2, 2003 | 09:54 AM
Menel's Avatar
1992 Maxima SE
Those tend to be rather expensive to replace if the connector isn't at fault.
Any recommendations on the best place to get one?
Old Oct 2, 2003 | 12:47 PM
LittlePiggie's Avatar
junk yard. the MAF is the same from 89-94 so it should be pretty easy to find one.
Old Oct 2, 2003 | 01:06 PM
subs1000w's Avatar
ive gotten 2 from local junk yards there small enogh that the junk yards dont even charge me for them if you know what i mean but proboly about 20 or 30$ otherwise
Old Oct 2, 2003 | 01:19 PM
more like 100. new they are about 250. if you go in and act like you need it for a a science project or something, it will be 20-30, but if you go in there talking the talk then it will cost you....unless you prefer the baggier clothes
Old Oct 2, 2003 | 09:46 PM
Menel's Avatar
1992 Maxima SE
not sure it matters anymore
left work today, R doesn't work
just revs...wtf?
tried twice since then
DJLAX152
May 4, 2021 11:46 AM
Mar 12, 2020 12:06 AM
RWCreative
Sep 21, 2015 11:01 AM
markevans999
Sep 10, 2015 04:29 PM
nbstriker10
Sep 4, 2015 04:26 PM
