this one is for the audio specialists
Old Feb 16, 2001 | 09:18 AM
90maxSE's Avatar
well in my max i have a jvc cd player and the stock bose setup, with that special wiring harness... now if i have the car off everything is fine, the radio, cd works fine, but when i turn the car on, meaning running, i get an alternator whine through my back passenger side speaker... now i can go around this by unplugging it but i wish to utitilize that speaker... any ideas??
Old Feb 16, 2001 | 01:09 PM
Matt93SE's Avatar
STFU n00b!
it's most likely a problem with the ground wires on that amplifier in the back. usually when you get alternator whine, it's the low-level ground signal coming from the head unit that is dead.. often on the bose amps, this is from a bad solder connection.
Remove the bose amp and resolder all the wire connections on the board, then see what happens. good luck.
Old Feb 16, 2001 | 05:15 PM
KHS's Avatar
KHS
ringing noise in my 90 gxe
Im not sure if this is the same alternator whine that has been talked about, but in my maxima, when i turn the car on, for about 10 minutes, there is this high pitched ringing noise when the radio is on. Its strange because after about 10-15 minutes, the sound is gone. ANybpdy know what this is?
Robert Schneeweis
Jan 11, 2017 06:47 PM
Fbana41
Aug 29, 2016 12:18 PM
Excalibur23
Oct 13, 2015 04:33 PM
BrandonCause
Sep 20, 2015 10:20 PM
popdedop
Sep 11, 2015 11:17 AM
