Re-installing injectors how?
Old Oct 10, 2003 | 12:16 PM
Thinkster's Avatar
I should be getting my serviced injectors back next week, so I removed to fuel rail and the seals and cleaned them. Since I still have one of the injectors (the bad one) I was seeing how it fit back onto the fuel rail injector port (Originally I took the injectors out with the rail still attached to the car). So, I first put the lower O-ring inside the rail injector port, then tried pushing the injector down into it. My question is, how do you get the injector in snug where it will not pop out? I could only push it down enough to where you could still see some of the top (larger) O-ring showing. I haven't tried yet putting the "holder hood" that goes over the top of the injector, So I just want to make sure I do everthing right cuz I don't want any leaks!
Old Oct 10, 2003 | 12:20 PM
Jeff92se's Avatar
I'm needing a caw
Does ANYONE read the stickies above???
http://www.cybrrpartspro.com/Chilton...961CH05_7.HTML
Old Oct 10, 2003 | 12:23 PM
nubiannupe's Avatar
OG Maxima.org Member
Looks like you're on the right track. However, I did a BIG write-up on installing the injectors early this year. It should either be in the FAQ's, or a search as far back as January should yield even better results.
(note that I didn't flame you here, but you may want to do a detailed search, as I found your answer therein and others MIGHT flame you...)
Old Oct 10, 2003 | 09:16 PM
jobasjr's Avatar
Chilton the #1 Source:
http://www.cybrrpartspro.com/Chilton...H05_1_IDX.HTML
Maxboy23
55
May 1, 2025 06:09 PM
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
msellas
Sep 23, 2015 09:16 PM
