less on ATF
Old Oct 13, 2003 | 06:17 AM
maximalover's Avatar
less on ATF
Guys,
I finally made up my mind to change transmission fluid for my 93 Maxima SE.. I drained and refilled ATF
I found out that I could only drain little more than 2 Quarts. I was expecting half of the full capacity. I think it should have been more like 4 Quarts..
I cheked the using the dipstick it was showing between cold and hot mark.
I put only 2+ quarts now because it is said not to overfill
Is there any thing wrong with the check I am making..? or if the vehicle is not level surface will it make a big difference..?
Appreciate your input guys..
Old Oct 13, 2003 | 06:37 AM
Matt93SE's Avatar
STFU n00b!
the vehicle must definitely be level, or tilted down in front, otherwise the fluid will run to the back of the tranny.
Also, be sure to follow the directions in the manual on how to check the fluid.. (run the car through the gears, let the tranny get warmed up, THEN check the fluid with the engine running and the tranny in neutral or park)
See what that tells you on the dipstick. you may in fact be a couple quarts low on fluid and don't know it.
mclasser
Aug 23, 2015 09:32 PM
max808
Jan 6, 2002 12:37 AM
max808
Dec 19, 2001 08:40 AM
Maximum Pursuit
Sep 27, 2001 04:31 PM
bill99gxe
May 15, 2001 07:31 AM
