Grinding and rubbing from front BUT NOT IN REVERSE
Old Oct 13, 2003 | 11:07 AM
KRMaxima21's Avatar
I have this weird sound coming from my front wheels and the faster I drive the louder the sound gets. It sounds a lil like the tires are flat and that they are rubbing the splash guards. But in reverse theres no sound. I'm on the highway and I hear it but if I turn the steering wheel slightly to the right around a bend the sounds fades out alot or when i hit uneven pavement and the front wheels are pushed up a lil it goes away again. Could it be from lowering my car and it did something to the front axle or could it be the rack and pinion or something ?
Old Oct 13, 2003 | 11:19 AM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
could be a bunch of things. first recheck your clearance turn the wheels lock to lock and make sure they arent rubbing.
Old Oct 13, 2003 | 11:31 AM
Matt93SE's Avatar
STFU n00b!
step #1 is to check your brake calipers and make sure they're bolted down properly. a while back, I had one bolt come off a rear caliper, and it tilted up and rubbed on the inside of a wheel. scary stuff. luckily I caught it almost immediately, or it would have been a nasty sight on the highway!!
pull the front wheels off and look for any signs of rubber. it could be the brake dust shield against the rotor, could be a caliper on a wheel, could simply be the fender liner rubbing on a wheel.
adamgalazka
Feb 5, 2023 08:24 AM
wyobbagy
Jan 3, 2023 12:03 PM
minsbang
Sep 11, 2015 08:48 PM
GregL65
Sep 5, 2015 09:37 PM
jfl330
Sep 4, 2015 01:44 PM
