I can't open the passenger front door!
Old Oct 22, 2003 | 11:26 AM
JamesDwan's Avatar
I have a '91 Maxima. The other day the door just refused to open (as I was dropping off my wife at her office). It still won't open! I tried taking off the door panel to get at the inside, tried the keyless enty-nothing worked. I am convinced some little plastic catch has broken. Does anyone have any suggestions?
Thanks in advance for any help on this matter.
JamesDwan
Old Oct 22, 2003 | 11:45 AM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
so the doors locked and wont unlock ? if the rod is broken on the inside your going to have to lower the window and get in there with something to unlock it. either a lockout kit or a coat hanger !
Old Oct 22, 2003 | 11:48 AM
KLoWnPR109's Avatar
one word ===>> crowbar
When you pull on the handle, is there resistance? Or does it just flop around?
Old Oct 22, 2003 | 12:12 PM
JamesDwan's Avatar
There is no resistance, and the door lock moves up and down like it should
Old Oct 22, 2003 | 12:14 PM
JamesDwan's Avatar
The locks go up and down when I lock/unlock the car. I opened up the door panel & found everything intact.
Old Oct 22, 2003 | 12:20 PM
internetautomar's Avatar
mod or sell?
sounds like the rod from the handle to the latch. does the inside door handle work?
Old Oct 22, 2003 | 02:01 PM
Bill Doran's Avatar
JamesDwan
My 92 GXE has had same problem in front passenger door for over 1 year. I, like you removed enough of the door panel to access the rods from the door handle & lock and no matter how hard I pull/push no good. 2 Dealer's have said they need to break door latch to open door and replace with new latch. Estimate $250+. I left car with one dealer for a day & then he told me he had to order parts and wanted deposit! Door latch is down low in door and can't be seen thru cut outs on inside of door. I hope to try myself to repair when my courage is up. If you repair let me know. Good luck
King_Ten_Ahead
Sep 30, 2015 04:27 PM
delerium75
Aug 19, 2015 11:08 AM
shaunkey1
Aug 18, 2015 10:09 PM
george__
Aug 18, 2015 07:06 PM
kjm900r
Aug 5, 2015 07:14 AM
