5speed problems
Old Oct 24, 2003 | 02:38 AM
89maxSE's Avatar
5speed problems
all the gears shift fine and all that good stuff till i try to go into 5th gear....if i try to shift into 5th just normally and then let out on the clutch i will hear a grinding. Not like the grinding when you try to put the tranny into gear w/o the clutch. it doesn't sound that bad. but then if i shift hard into 5th, 95% it will go in w/ no problems. Any suggestions?
Thanks,
Cole
Old Oct 24, 2003 | 08:05 AM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
could be a few things, shifter adjustment, syncros, the sleeves that go into the tranny, ect...
Old Oct 24, 2003 | 08:33 AM
bobbydigital450's Avatar
I had the same problem, it only did it at higher RPM's, but it ended up being a snycro. Probably pretty close to rebuild time.
Old Oct 24, 2003 | 10:41 AM
89maxSE's Avatar
I've heard a lot of good things about Lucas. Do you think that could help any in this situation?
Old Oct 24, 2003 | 06:29 PM
Maxima90SE's Avatar
is it better to rebuild ur tranny or buy a used one or buy a rebuild one?
my tranny is whining like crazy and it is getting a louder and louder
Old Oct 24, 2003 | 08:23 PM
Depends on how cheap you can get a used one for. My pops is a "transmission specialist" so I had him rebuild mine. Sounds about like the same problem i had, bout $180 in bearings and a syncro. However, I just bought a used VE tranny with 70k on it for $150, my "transmission specialist" appearantly forgot somthin, cuz it got stuck in reverse and I had to drive it clear across town backwards at 2 in the morning with tinted windows. im a say get a used one. But if you want, ill sell you the bearings out of mine. Probably no more then 300 miles on them.
Old Oct 25, 2003 | 02:02 PM
Maxima90SE's Avatar
but which is more reliable?
u only paid 150 for the tranny but paid 180 for bearings and syncro..that doesnt include the labor? how much would it cost for the labor?
user 11122324
42
Jul 18, 2022 03:35 PM
Unclejunebug
Apr 2, 2016 05:42 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Noela
Sep 26, 2015 08:22 AM
