Bad Jerking when accelerating.....
Old Oct 27, 2003 | 03:35 PM
NEWGUY's Avatar
ANyone had this. I push the gas pedal down and all the car does is jerk and the tach goes up and down.
If you drive like a granny there seems to be no problem, but as soon as you push the gas down to kick it down a gear (AUTO) it starts the jerking thing horrible.
Let me all know what you think.
NEWGUY
Old Oct 27, 2003 | 06:17 PM
internetautomar's Avatar
mod or sell?
Check your TPS to start with. or take it to a competent and reliable trans shop.
what color is your trans fluid?
How does it smell?
Old Oct 27, 2003 | 07:24 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
mine smells like peaches.
Old Oct 28, 2003 | 02:39 AM
NEWGUY's Avatar
Sorry, what is TPS????
I have not look at tranny fluid....
Thanks for any more input.
Old Oct 28, 2003 | 06:22 AM
mod or sell?
Throttle Position Sensor.
Trans fluid should be Cherry red not burnt sienna red. and shouldn't have any real smell to it
Old Oct 28, 2003 | 06:24 PM
Scope's Avatar
Im izz sexay
My car does the jerking too but if I let it "warm-up" for about 5 minutes before actually driving it then it doesn't do that as opposed to just pulling off. This only occurs in the winter time though.
Old Oct 29, 2003 | 03:30 AM
NEWGUY's Avatar
My car does it hot or cold, does not matter. But mostly when you push the accelerator down to kick it down a gear and then it bucks.
I talked to my local mechanics ( GOOD FRIENDS) and they said right off the bat it had to be 1 of 2 things: Either the coil pack or the fuel injectors, so i take it in today to have them look it over.
Anyone have any links to where i can find these two items cheap?
Old Oct 29, 2003 | 06:34 AM
mod or sell?
UMMMM...... which yr/model do you have it's not in your sidebar.
Old Oct 29, 2003 | 09:56 AM
NEWGUY's Avatar
1990 Nissan Maxima Base model one, i just got it this weekend.
Old Oct 29, 2003 | 11:25 AM
mod or sell?
weekend.
You got NGVG injectors in your car.
Advice: Buy 6 brand new not reman, there is a very high defect rate on those particular injectors.
But they are quite likely at least part of your problem.
Old Oct 29, 2003 | 03:30 PM
Ninty-two-se's Avatar
Where is the TPS located? My new car has this problem but my old one doesnt so I wanted to just switch the sensors to see if it makes a difference but I wont have time to get chiltons guide or anything like that because I wanted to do this tomorrow afternoon
Old Oct 29, 2003 | 04:13 PM
AscendantMax's Avatar
is it the usual jerk from downshifting or it jerks rough?
Old Oct 29, 2003 | 05:15 PM
mod or sell?
On the throttle body normally. check the online chiltons
Old Oct 29, 2003 | 05:54 PM
klymkow's Avatar
Have the timing checked.
Very easy to check/adjust and can cause the problems you are having. Since you just got the car, someone may have improperly adjusted the timing previously.
If the problem persists after timing adjustment, move on to the other items being mentioned.
Good luck,
Tim
Old Nov 10, 2003 | 06:48 AM
NEWGUY's Avatar
Jerking is only when you kick it down and then it only bucks once or twice. (RPM's go from about 3500 to 1000 and then back real quick) I just had the wires and plugs replaced and it stopped for several days and then when it rained this week it started to do it again.
ALso when i tried to start it that day too, it just turned over and over and never started, i had to try it 3 times before it started.
chisam14
Nov 6, 2018 08:56 PM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
