turbo ve????????
Old Oct 28, 2003 | 06:30 PM
espimax's Avatar
turbo ve????????
have any one done a turbo kit or know some one that could do the exhaust manifold for the ve30de motor, any info will be apriciated.
Old Oct 28, 2003 | 06:35 PM
Nozama's Avatar
Grumpy old guy
I'll be the first to say.....SEARCH.
Probably not the last though.
KLoWnPR109's Avatar
Currently, there is no turbo kit available, but there is one or two in the works
mtcookson's Avatar
no turbo kit as of yet. good exhaust shops will be able to make a manifold for you. they are pretty pricey though.
edit: dang... didn't respond quick enough. now i'm echoing
Old Oct 28, 2003 | 06:40 PM
espimax's Avatar
if any one out there now of a prtotype for sale please let me know, and yes it is pricy and downtime is about a week, thank you guys
Old Oct 28, 2003 | 06:50 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
i believe theres one in the works im waiting on one myself. however after all the jeers its gotten about turboing a n/a motor and blowing it up im hesitant.
Old Oct 28, 2003 | 06:51 PM
mtcookson's Avatar
yeah, you guys have high compression. i forgot about that. i'm sure the engines will be fine if you supply the right amount of fuel and keep boost low. it's possible to crank tons of boost on high compression, you just have to tune it really well.
Old Oct 28, 2003 | 07:00 PM
espimax's Avatar
unless you get carry away trying to push 12 psi or more we should be ok i will be just happy with 8 to 9 psi i`m not traying to impress any one or brake a world record or brag about hp. to the wheel, i`m looking for better performance that is it.
Old Oct 31, 2003 | 12:54 PM
StRacer718's Avatar
I've already looked into the turbo thing numerous times. Its very expensive since it has to be custom, and every place I go to says unless you build the engine to handle boost the most you could do safely is 5-7psi. From the prices I been getting im not going to get a turbo and only get 5-7 pounds.
Although I do love the sound of those blow off valves!!
Old Oct 31, 2003 | 12:58 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
how do they know that when no one has pushed the limits on one??
Old Oct 31, 2003 | 01:00 PM
subs1000w's Avatar
theres a guy with a forth gen running 5lbs and he dynoed at 255whp and thats about estimate 80more whp than you have and youd be able to sit side by side with a z28 camero on the highway now so if thats not enough theres somthing wrone with you. there are guys running 10lbs with about 325whp so you can run more than 7lbs safely but it cost more also
Old Oct 31, 2003 | 01:06 PM
Matt93SE's Avatar
STFU n00b!
How many hundred times do we have to see this thread?
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
BkGreen97
Apr 2, 2016 05:47 AM
09maxshawn11
Sep 30, 2015 10:28 AM
Keyno McMike
Sep 21, 2015 07:18 AM
