91 SE headlight problems
I just bought a 91 SE Maxima. When bought the headlights were busted ( both literally popped ). I replaced the bulbs and it happened again. Is there a known cause for this that is common for these cars? Ive only had it less than a week and Im thinking about getting rid of it.
didn't touch the bulb did you? if not, there is most likely a wiring problem. i would just trace the wires from the bulb as far as you can. if isn't any wire damage then i'm not really sure.
Originally Posted by davebond007
Check the fuse.
If it comes down to it you can do a custom relay job that usually yields brighter headlights using stock bulbs (more power).
AaronL
Nov 15, 2020 11:52 AM
MaxLife17
Jun 27, 2019 01:37 PM
03VQMAX
Nov 10, 2015 03:39 PM
