Sunroof question
Old Nov 3, 2003 | 07:53 PM
rrrfoma's Avatar
Sunroof question
Hi,
Does anybody know how to fix sunroof flapping (in other words, with a small push the front end of the sunroof moves up a little; the same thing with the back side).
I have already checked - weather stripping is fine.
Thanks,
Alex
Old Nov 3, 2003 | 07:56 PM
internetautomar's Avatar
mod or sell?
Originally Posted by rrrfoma
Hi,
Thanks,
Alex
Sounds like a worn track or bushing
Old Nov 3, 2003 | 08:10 PM
rrrfoma's Avatar
... which is how check/fix ?
I thought it might be some easy fix without taking of the whole thing out
Old Nov 3, 2003 | 08:33 PM
Pyrophilus's Avatar
I have same problem (sunroof glass rattling), but it's strange, because it was present since the car had about 30k mi. It is now over 10 years old, but the rattling was something that was in my car for as long as I can remember.
I do remember almost a year ago, seeing a "fix" where somone stacked some washers and installed them to stop the rattle, but I didn't save the URL, and I can not seem to find it anymore. Maybe the fix actually didn't work, and the person took the how-to off...
If anyone has answers, I'd really appreciate them.
-Sage
Old Nov 4, 2003 | 01:37 PM
rrrfoma's Avatar
I checked with dealership - they are clueless ...
Did anybody fix sunroof assembly before?
Old Nov 6, 2003 | 08:58 PM
rrrfoma's Avatar
so I guess nobody ever had problems with a sunroof or removed it ...
Old Nov 6, 2003 | 09:02 PM
Jack.'s Avatar
Wait, it's rattling or what? If so, then just tighten down the bolts holding in the glass by simply removiving the two molding pieces.
Old Nov 7, 2003 | 05:43 AM
rrrfoma's Avatar
sounds like a simple fix - I'll try it this evening.
thanx!
Old Nov 7, 2003 | 11:19 AM
89sks's Avatar
should be able to find it in a search, take off the plastic covers from the inside and unscrew the glass from the tracks, add a few small washwers between glass and tracks then retighten, it helped mine get a lot better but still rattles some times.
Old Nov 9, 2003 | 10:14 PM
rrrfoma's Avatar
which washers size did you use?
should I add 'em just to the front or rear as well?
thanks
Old Nov 10, 2003 | 05:35 AM
89sks's Avatar
I took the sunroof off and looked at the little bolts and just guessed when I bought a small package of small washers. Sorry I can't be of more help there, they were about the diameter of a pencil with a hole large enough for the little bolt to go through.
Old Nov 10, 2003 | 07:27 AM
rrrfoma's Avatar
Actually I was asking how thin they should be ...
Old Nov 10, 2003 | 08:19 PM
94MAXGXE
"I checked with dealership - they are clueless ..."
Now there's the quote of the day.............
I agree....My local dealer has NO IDEA how to service my 94.......If it's not a 2k+ they have NO CLUE !!!
Old Nov 11, 2003 | 01:57 AM
bonzelite's Avatar
rattler
i have the same rattling problem. i have found it to be minimized when i close the sunshade. often disappears. however, i will take the advice of removing the molding and then tightening the bolts. that seems simple enough. the rattling is annoying.
bigdogsteve
Jan 31, 2018 04:18 PM
Fbana41
Aug 29, 2016 12:18 PM
Forge277
Jun 13, 2016 09:26 PM
Unclejunebug
Apr 2, 2016 05:42 AM
jonreidhead
Jan 6, 2016 09:38 AM
