mounting 6 1/2"s in doors..having issues after 1st attempt
well here it is:
I took the stock speaker pods and cut a hole to fit the 6 1/2s. i tried to put the door panel on and it appears as the speaker is hitting the panel keeping it from going into place. for those of you that have installed larger speakers, how did you get them to fit? im going to try to sand down some plastic to see if it'll fit.
I put in 4x6
a little bigger then the stock 3 inch...and it worked. I cut a hole in the BOSE speaker pods, then screwed the speaker in. Maybe the speaker DOES fit and you're just havign a problem putting the door back on? the doors a *****, get the handle on first, then the lock, then line it up at the window sil...I remember a lot of room between the pod and the door so I don't see how you're having a problem there.
PJ
PJ
