VG idle RPM?
Old Nov 4, 2003 | 07:06 PM
Pyrophilus's Avatar
VG idle RPM?
I tried to fix my broken tach. I took the cluster apart, and resoldered every connection, dremeled the screw threads (because they are the ones that make the connection), and now the tach works. One problem.
While soldering, I accidentally popped the needle off, and I tried to stick it back on. I think I must have put it on at a wrong setting, because when I floor the car, and the A/T shifts from 1st to 2nd at redline, the tach now reads 4700RPM.
I am thinking that I'll remove the cluster lens, re-install it, and pull the needle off, start the car, and at idle, replace the needle at the engine idle rpm...
My only question is, can anyone tell me what their idle RPM is? I have the VG engine in a 92 GXE.
Thank you,
-Sage
Old Nov 4, 2003 | 07:10 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
700 i believe
Old Nov 4, 2003 | 07:18 PM
AscendantMax's Avatar
750 after normal engine temp. think 1100 cold idle
Old Nov 4, 2003 | 07:43 PM
jaguax's Avatar
How does the needle pop off anyway? I replaced my cluster with an SE white faced one so I was experimenting with my old cluster trying to take the needles off and whatnot. Well I pulled very hard on the needle but it would not come off!
Old Nov 4, 2003 | 08:04 PM
you don't just pull them off, i believe they are screwed on. i remember reading a writeup someone posted awhile back.
Old Nov 4, 2003 | 10:15 PM
Bill Brasky's Avatar
Seperated at Birth?
my cold idle is 1500. it then goes down to ~650
Old Nov 5, 2003 | 12:26 AM
bonzelite's Avatar
idle talk
those readings sound about right. about 700-750 warm. about 1000-ish cold. 1500 sounds a wee bit high. check that.
Old Nov 5, 2003 | 03:13 PM
|Bijan|'s Avatar
UCF Lexus
750-800
Old Nov 5, 2003 | 07:12 PM
bonzelite's Avatar
marietta or bust
Originally Posted by bijan gxe
750-800
oh, bijan gxe >>> i see you're in marietta, ga. how is the big chicken these days? do you live near smyrna? or kennesaw?
Unclejunebug
Apr 2, 2016 05:42 AM
Need help
23
Oct 2, 2015 08:56 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
