Trunk Not Locking
Old Nov 6, 2003 | 03:17 PM
MR FINGAHZ's Avatar
Trunk Not Locking
My trunk latch is not locking first of all. The button is not working, you hear the motor but the latch still doesn't lock. Any Ideas?
Old Nov 6, 2003 | 04:47 PM
internetautomar's Avatar
mod or sell?
ummmm.. do you mean unlatching? you push the button to "unlock" not "lock" the trunk
Old Nov 6, 2003 | 04:52 PM
MR FINGAHZ's Avatar
exactly it's not latching at all it's just closed.
Old Nov 6, 2003 | 05:03 PM
mod or sell?
So it's not staying closed and latched?
It's always open and unlatched?
Just trying to make sure I understand the problem
MR FINGAHZ's Avatar
I can walk up to it and just lift the lid.
Old Nov 6, 2003 | 05:05 PM
mod or sell?
try moving the latch with a screw driver. it may have gotten caught in the wrong position.
do it while some one is pushing the release button
Old Nov 6, 2003 | 05:33 PM
rrrfoma's Avatar
I would suggest to use a key instead of pushing the release button.
If key doesn't turn - latch is caught in the wrong position or just frozen.
But in any case I would take out the lock (including latch), as well as links (check the links first - they might be the cause also).
Old Nov 6, 2003 | 05:43 PM
MR FINGAHZ's Avatar
I have had the car for about 3months now and the key never worked. I have always used the release button. Before it stopped latching it used to make a loud click noise when it unlatched now the sound is low and muffled there is no loud unlatching sound.
Old Nov 6, 2003 | 06:26 PM
rrrfoma's Avatar
I think your problem is mechanical.
Open the trunk and remove a cover from the trunk door. You'll be able now to access trunk lock and all mechanical part. Check all the links if they are in tact. Detach link from the lock (be carefull with link plastic locks) and try to open the lock by moving it. If it works - links are the problem. Connect them back and see if it works.
If not, remove lock assembly and fix it (I hope you have some simple tools).
Next step is to fix you trunk lock - see other thread posted 5-7 days ago.
Hope this helps
Old Nov 7, 2003 | 09:01 AM
MR FINGAHZ's Avatar
Hope this helps
thanks alot for your help.
REDinLV
Aug 15, 2024 12:30 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
ajahearn
Sep 19, 2015 03:03 PM
Hailstatejig
Sep 2, 2015 06:52 AM
