Which Spark PLugs?????????
First i would like to say im new here and hope to make lots of friends that can I can help and can help me.
I just purchased a 92 SE. I replaced the plugs with Bosch Platinum Plugs. I have the motor with the coils and no wires. The car just hit 74k. NO MODS. Are these plugs coorect or should i be using different plugs. The car has a very slight ruff idle and i would like it to go away. I shouldnt be able to tell the car is even running. Also what should the car idle at? Its a 5spd. I am also having a hard time finding the PCV also. I changed the fuel filter already.
Any and all help will be greatly appreciated!
Thanks!
Thanks!
Originally Posted by cneary812
first of all welcome, next thing take advantage of the search function it has lots of info. You can also learn alot from looking around.
about 700rpm
pcv valve is on back side of manifold plenum right side by firewall.
about 700rpm
Thanx alot guys im searching now for the answers. I like the car alot and i can wait to start the mods!!!!!!!!! Im sure I will figure it out. And the plugs are the single plats not the 4's.
no problem
I acutally have +2's but lots of different preferences here. Also check out the FAQ's there is lots of good info and links that will help you out alot.
Originally Posted by harrymay
all i know is that you shouldnt use the bosch platinum 4's, ive herd the best are the NGK's
NGK's are the best for our engines IMHO. I'm running the NGK BKR5E-11. It's the copper v-power plug. I prefer the coppers because because you can get 6 coppers for the price of one platinum.
Ok i think im taking the Bosch out and putting in NGK 2271's. Please let me know if these r the correct plugs for a 92 VE motor.
I would also like to know what type of mods I should start out with. I just Got the car its a 92 se with VE motor and a 5 spd with 74k. I was driving a 89 mustang gt with 300 rwhp for a year so this car feels alil slower.
Also i saw a 3rd gen Max with diff dash bulbs. Does ne one know what bulbs are behind the dash guages?
Any help would be great!
Should I change the wires along with the spark plugs? The problem with that is I can't exactly afford new wires with all this other crap I'm buying.
I think I'll stick with the wires that are on there now and just buy some NGK spark plugs.
06-06-2017 02:01 PM
magiconthetire
10-26-2015 09:03 PM
Need help
23
10-02-2015 08:56 AM
