Need Differential!!!
Old Nov 20, 2003 | 08:51 AM
Dysfunctional
hey guys,
i need to get a differential, i've got a VG ... i called everywhere and i dont know (niether do they) if any differntial will fit my tranny i went to the Nissan dealer ship to get information to see if any tranny will fit, and none will, then i asked if any other tranny will fit and they can't say yes, or no, b/c they dont know. so pretty much i found out that the nissan dealer ship doesnt know anything about transmitions. so im still looking for some customizing shop or someone that could do the job. but as now, there is no luck.
so i'm thinking about a tranny swap, or do a custom differential install,
and any other information about anything will help
do you guys know anyone that does this kind of work, well all the information would help, thanks alot
-Dys
Old Nov 20, 2003 | 08:58 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
whats are you talking about?? pretty sure there is a differential in the VG tranny. and use the search...VE 5spd tranny swap with LSD is possible or you can have custom LSD made by Phantom Grip or something(I know someone doing this as we speak for a VG)
Old Nov 20, 2003 | 09:40 AM
internetautomar's Avatar
mod or sell?
the whole trans will swap from 89-93 according to hollander
Old Nov 20, 2003 | 09:43 AM
Jeff92se's Avatar
I'm needing a caw
Since the diffy is an integral part of the transmition(hehe!), you pretty much have to replace the whole thing. Maybe a quaife? That would be $1200 or so + installation.(if they even have one for the old VG transmition(hehe!).
Old Nov 20, 2003 | 09:47 AM
DanNY's Avatar
Ad·min·is·tra·tor
see if you can fit one from a Ford. the posi rears will help a lot in the traction.
Old Nov 20, 2003 | 09:53 AM
Dysfunctional
what one from a ford??
and i went to the nissan dealer ship and they said that a 92-94 wont fit b/c it bolts up to the VE ... and they said it wont work
or will it?
and quaffe doesnt make one for the VG
and no i dont have a differentail that allows me to lay "duals" when i burn out, all it does it "HOP" ... i hate wheel hope so i wanted to just do a diff.
Old Nov 20, 2003 | 09:56 AM
Jeff92se's Avatar
I'm needing a caw
Um.... say what?
or will it?
Old Nov 20, 2003 | 10:48 AM
MrGone's Avatar
Impossiable.
Our Differiential is built into the transmission, which is actually why its called a Transaxle.
As DA-MAX said, aside from a factory unit, unless you can get one from PhantomGrip, your SOL. Also BigDogJohnX had one custom built for his 2001 SE Turbo, might ask him for the contact info for the guy who built his.
Ford Posi is the same thing as a clutch based LSD last time I checked.
Old Nov 20, 2003 | 11:07 AM
mtcookson's Avatar
the differential will come out, at least in the RS5F50A (VG tranny) it will.
that nissan dealership is full of idiots. the RS5F50V (VE limited slip tranny) will bolt up to the VG engine. i think the things you have to change on the car are the axles and the hubs since the splines on the axles are different or something like that. the case on the RS5F50V is also a bit bigger where the lsd is because of the lsd's larger size, from what i've been told.
if you want less wheel hop, polyurethane motor mounts are supposed to fix that. the only problem is you have to make them yourself since none are made for our cars.
Old Nov 20, 2003 | 11:22 AM
Dysfunctional
ok,
so let me see,
if i get a VE limited slip and get a new axle, it will go in
OR i could call up phantom grip and ask them to make me a custom limited slip that would probably be MUCH MUCH better, also MUCH MUCH more exspensive.
does anyone know where i can get the urathane to make the mounts? and i think i know how to make the mounts but maybe a write up or just some instructions ... thanka lot guys your SOO helpful.
Old Nov 20, 2003 | 01:17 PM
MrGone's Avatar
And Hubs/spindles.
Or you could do what I said and ask a specific member about a custom LSD.
Urethane for the mounts.... Home Depot? I think Aaron ordered his online, not entirely sure though.
Old Nov 20, 2003 | 01:19 PM
DanNY's Avatar
Ad·min·is·tra·tor
flexane
www.mcmaster.com
i can bet the next question to ask is WHICH TO GET.
you people need to effin SEARCHHHHHHHHHHHH!!!!!
Old Nov 20, 2003 | 05:08 PM
davebond007's Avatar
You could hack a piece of delrin in there along with some polyurethane for a bit more stiffness.
Old Nov 21, 2003 | 01:37 AM
crazy4maxima's Avatar
http://www.geocities.com/CapeCanaver...-r/mounts.html
Old Nov 21, 2003 | 08:21 AM
farkum's Avatar
or will it?
You obviously dont know very much about cars because laying "duals" does not mean that you have a differential, it just means that you either have a posi diff or a limited slip diff. Every car has to have some sort of differential or the tires would wear so fast it would make your head spin.
Old Nov 21, 2003 | 08:32 AM
mod or sell?
Street cars that is
Old Nov 21, 2003 | 08:55 AM
DanNY's Avatar
Ad·min·is·tra·tor
why not just a piece of alum.
Old Nov 21, 2003 | 09:16 AM
subs1000w's Avatar
you could not steer a front wheel drive car without a dif, now rear wheel drive is a diffent story lets just say alot of loud chirps around turns
Old Nov 21, 2003 | 09:52 AM
MrGone's Avatar
No, you could not steer your FWD car with out spindles or CV axles.
A differiential transfers motion, it will only make the wheels lock up if you have a locker or spool installed, or if you weld it.
James92SE
142
Jan 2, 2024 09:23 AM
Pied
Sep 26, 2015 03:29 PM
altmycar
Aug 6, 2015 04:44 PM
ericdwong
19
Oct 23, 2001 10:53 PM
ericdwong
Oct 16, 2001 06:06 AM
