fuel pump
Old Nov 22, 2003 | 10:33 AM
Grisadiche's Avatar
fuel pump
i just found out that the reason my car wasn't starting.......it wasn't getting fuel. so i was wondering how much a shop would charge to do a job like this, and how much in parts, and what parts i need........any help would be appreciated. thanks
Old Nov 22, 2003 | 10:54 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
replacement probably takes about 1 hour or so...(the "or so" is if they have to struggle to get the stubborn fuel lines back on ) truthfully its a very easy job, you could probably do it yourself if comfortable.
Old Nov 22, 2003 | 04:51 PM
internetautomar's Avatar
mod or sell?
Check here http://e-toolbox.com/ads/rq.cfm for directions and save the money!
Do it Yourself!
Wanna buy a fuel pump?
Old Nov 22, 2003 | 06:41 PM
dadster's Avatar
My fuel pump quit last year and after some research here and on other boards I found the Walbro aftermarket kits. It is an easy 1 hour job.
You pull the fuel pump fuse and start the car to drain off any fuel pressure, remove the bottom rear seat and take the fuel pump out from the top of the fuel tank. Remove old pump from the bracket, assemble the Walbro parts and reinstall.
Dealer wanted $450, did it myself for right at $100.
Here's a link to the parts involved:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2443580428
Fred
Old Nov 23, 2003 | 06:34 AM
Grisadiche's Avatar
wow, thanks guys, i'll probably do it myself then, are there any tricky parts that might give me a real problem though??
Old Nov 23, 2003 | 06:38 AM
mod or sell?
yeah getting the fuel lines off the sender
Old Nov 23, 2003 | 06:39 AM
Grisadiche's Avatar
alright, maybe i'll wait till next weekend then, one of my brothers friends is a mechanic, he'll probably feel a little more comfortable than me doing this.
Old Nov 23, 2003 | 06:40 AM
Grisadiche's Avatar
but that walbro aftermarket kit will work though, right??
Old Nov 23, 2003 | 06:51 AM
mod or sell?
Most aftermarket companies will make a fuel that meets the requirements of the stock motor. If you want to go above that then you will need to know much more
Old Nov 23, 2003 | 02:51 PM
Grisadiche's Avatar
well, how do i find out much more, and what benefits and disadvantages will i have using certain pumps and stuff??
Old Nov 23, 2003 | 02:52 PM
Grisadiche's Avatar
and yes, i will be needing to buy a fuel pump
Old Nov 23, 2003 | 03:11 PM
Matt93SE's Avatar
STFU n00b!
Walbro has about 3 pumps listed for our cars. a high volume low pressure, a high pressure low volume, and a high pressure high volume.
Go with the "low pressure high volume" pump. unless you're planning NOS or turbo, then you don't need the high pressure one. the high volume, low pressure one will work GREAT on your car.
Old Nov 24, 2003 | 04:15 AM
Grisadiche's Avatar
thanks, i'll take a look see
Old Nov 24, 2003 | 10:52 AM
Grisadiche's Avatar
the ebay link is to a high pressure pump, will the low pressure high volume pump be less expensive, and where should i look to get one?
Old Nov 24, 2003 | 10:53 AM
DA-MAX's Avatar
autoperformanceengineering.com ....they sell the Walbro low pressure replacement for $80 or 90 I think
Old Nov 24, 2003 | 10:56 AM
Grisadiche's Avatar
thanks for the help, i'll let you know how it turns out for me.
Old Nov 24, 2003 | 10:59 AM
Grisadiche's Avatar
so you would recommend the 190 ltr/hr pump kit for 85??
Old Nov 24, 2003 | 11:02 AM
DA-MAX's Avatar
yup, FPN007
Old Nov 24, 2003 | 11:04 AM
Grisadiche's Avatar
yeah, thanks, i'll probably order it tonight then
Old Nov 27, 2003 | 12:20 AM
maxed up's Avatar
me too, thanks
Old Nov 30, 2003 | 03:07 PM
molehill84's Avatar
Hey guys...I bought the Walbro 255 LPH fuel pump, I was wondering if I need a new fuel pressure regulator or if the stock one will work. I will be running a 55-65 shot from a Zex Kit.
jmlee44
Oct 2, 2022 02:13 PM
Miket2006
Mar 1, 2021 03:55 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
