keyless entry: somehow making a siren "chirp" on lock/unlock
Old Feb 24, 2001 | 01:11 AM
ngthing's Avatar
right now, I have a remote start /w keyless entry. when the door lock and unlcok my parking lights flash, is there a way to add in a siren that chirps on lock/unlock?
Old Feb 24, 2001 | 05:39 PM
Brandon90gxe's Avatar
hmm... dunno if your remote start came with a siren, but i have mine setup to have that beep that the keypad makes when you push the buttons, and it sounds pretty sweet
Old Feb 24, 2001 | 06:10 PM
nubiannupe's Avatar
OG Maxima.org Member
Jon,
Actually, I have a diagram that shows how you could add that to ANY existing system. I'll look around to see if I can find it. If not, I'll try to give it to you from memory. If I CAN find the diagram, I could fax it to you, or I'll just try to explain it to you as best as I can.
Old Feb 24, 2001 | 07:19 PM
ngthing's Avatar
Originally posted by nubiannupe
Jon,
That would be great! What type of siren should I purcahse? There are some annoying ones, the one I like is more like a ""blip", is there a way to test a siren befoereI buy?
Old Feb 28, 2001 | 11:13 PM
bigjay's Avatar
d.e.i.
You probally have the dei which is a viper sold under a cheap name,if so you can hook the siren up to the remote start, it is 2 wires and you connect it into your acc. spot on the brain which is ushually tucked under the dash near your hood latch, if this is a non dei or viper, most likely it is simmilar,also ushuall mounting space is behind the master cylender on the fire wall( ps i recomend you relocate the alarm to a place where you can't just reach under and pull it out, this will disable the starter but not a thiefs ability to rob that ***
05RLS2
Sep 27, 2015 09:24 PM
flu2000
Sep 14, 2015 12:34 PM
thenewguyy
Sep 12, 2015 11:12 AM
Hailstatejig
Sep 2, 2015 06:52 AM
